first one is an l plug, small L not big L. It's for the thermoswitch that turns on the thermofan
as for your second one thats seperate of the ignitor?
Car - ae86
motor - 4age 20v (to be installed)
use - conversion
problem - Unidentified Plugs
1st Question is probably an easy one - what plug is this? (located next to the ignitor on the 20v loom)
2nd question is this a RC filter? I assume it just gets rid of the noise on the ignition lines, haven't traced it back yet.
click on the last link
if you look at the bottom it has a diagram of all the connectors and their number, you get that and look for the same letter on the diagram which is on the bottom far right side.
Yes you are right about the 2nd one, its a filter to get rid of noise.
