Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 37 of 37
Thread: weird annoying ticking noise
  1. #31
    Joshua
    Southport
    sounds like the big end bearings knocking the sump, this only happens when the oil is hot and the oil filter is too free flowing. of course according to my hearsay experiece
  2. #32
    Site Supporter Javal's Avatar
    Josho
    Cocaine's a hell of a drug, son.
    Exhaust leak. Machine extractors, replace gaskets, cease worrying.
  3. #33
    Jason
    Southern Suburbs
    To pin-point the sound, get some rubber hose/tubing about 1m in length, 3/8"ID.
    Put one und up to your ear, the other end systematically move it around the area you think the noise is coming from. Quite easily you will be able to identify where the noise is coming from as it will get louder. The tubing helps shield noise from other area's of the engine bay.
    And use genuine gaskets, the SHIT you get from local autostores is cheap for a reason.
  4. #34
    Veteran Nikkojoe's Avatar
    Tom
    Never had a problem with non genuine stuff, and I even re-used it many times when I had my engine issues. No leaks
    Sometimes though, genuine are actually not that expensive (specially for intake gaskets, cheaper than the aftermarket and it's easeir to get).
  5. #35
    Senior Member .ady's Avatar
    Andy
    Footscray
    machining really needed? mate told me to use brass exhuast silicon as well
    yes?yes?yes?
  6. #36
    Veteran Todd's Avatar
    Feb 2010
    Todd
    SOR Perth
    machining not 100% necessary, but depending on how old/bad they are it might be worth thinking about.
    would only be about 30 bucks to get them faced, and save you a whole lot of pain/financial annoyance if u were to keep popping gaskets in the mean time.
    and yep. any exhaust silicon is good to use. although i have never ever had an issue with maniseal. besides they fact it is fucking crap when u get it all over your hands (wear gloves).
  7. #37
    Josho
    I would, but i'm not you. I try to avoid using exhaust sealant where possible, it's rarely the 'right' way to fix it.
  1. weird noise in a 4age
    By wanted_ae86 in forum Technical - Questions
    Last Post: 5th September 2011, 11:05 PM
  2. 4AGE hesitation and weird induction noise - HELP
    By barbel in forum Technical - Questions
    Last Post: 26th July 2010, 07:41 PM
  3. weird noise
    By michaeltay31 in forum Technical - Questions
    Last Post: 7th February 2010, 09:57 PM
  4. 4age - ticking noise
    By pogi in forum Technical - Questions
    Last Post: 13th July 2009, 03:17 PM
  5. weird engine noise! advice opinions please.
    By FKN16v in forum Technical - Questions
    Last Post: 5th June 2007, 10:20 PM
