i have a fwd one if that helps at all?
hey everyone,
i'm after a bigport throttle position sensor asap. any help is much appreciated.
part number is 89452 - 14050 DENSO
has horizontal "wings/tabs"
timbo
did a bit of forum researching and copied this from 70XIN:
89452-20070
89452-28010
^^ Ae86 TPS Part #'s
89452-12040
89452-14050
89452-20050
^^ Ae82 TPS Part #'s
so i have an ae82 TPS thus needing a non-buggered ae82 TPS!
hmmm i'm not sure... part number is 89452 - 14050 DENSO
The thing that matters is that if it's adm or jdm as they have different wing actuators (adm horizontal, jdm vertical).
That said you could get any to work if the wing actuators to suit are provided with the tps.
ahhh ok, well it is jdm is that helps anyone. cheers for the info blokes!
edit: just took the part off and when the throttle is closed the tabs for the TPS are horizontal... another japanese engine swap mystery!
well yeah let me know if you can use mine at all, thanks for the info nikko
any chance of posting up the part number?
first post edited, i think you and i are in luck...
bumpity
up it goes for the running of my car
mods please close this thread.
