Results 1 to 4 of 4
Thread: 4age check connector, high idle
    Member khoala's Avatar
    Khoa
    Default 4age check connector, high idle
    engine: 4age bluetop tvis cut shut manifold
    4age idles high (around 2000-2500 rpm when warm, sometimes bounces like a stripper on a pole from 1000 to 1500rpm) so i thought i'd do a diagnostics check...turns out that my check connector is missing. is there a plug which the check connector plugs into? and if so, are there any check connectors from other cars which are compatible with the 4age loom?
    also, anyone have a clue why my 4age idles so f*** high? ive checked the map sensor vacuum, bottomed out the idle control screw, checked the butterfly valve is fully closed, checked all engine grounding points. i doubt its a dizzy timing issue, so all i can think of is:
    - fuel pressure regulator?
    - TPS?
    - f*** up throttle body? (auxillary air valve was removed and a plate bolted in to block all the holes up)
    - karma?
    any help is appreciated guys, cheers khoa
    Veteran slide86's Avatar
    Huw
    Hills
    you have an air leak somewhere post throttle body
    Veteran Nikkojoe's Avatar
    Tom
    Check that the cut and shut manifold doesn't leak
    Veteran timbo's Avatar
    Tim?
    Wild West
    get a can of contact cleaner and spray it around the manifold. if the idles dips then you know you have a leak.
  1. High idle - the endless saga
    By Golberg in forum Technical - Questions
    Last Post: 4th May 2009, 08:19 PM
  2. high idle, please help
    By callum1 in forum Technical - Questions
    Last Post: 29th December 2008, 09:52 AM
  3. 4age HIGH idle
    By stylz in forum Technical - Questions
    Last Post: 27th July 2008, 08:39 PM
  4. where is the check connector?
    By AE86.cn in forum Technical - Questions
    Last Post: 4th June 2008, 02:36 PM
  5. help with high idle
    By DriftPlease in forum Technical - Questions
    Last Post: 14th January 2007, 06:11 PM
