Results 1 to 10 of 57
Thread: funny idle / no throttle responce no tacho.
    Jul 2009
    Daniel
    Morisset
    Default funny idle / no throttle responce no tacho.
    Car - AE86
    motor - Small port 4A-GE
    use - supposed to be my daily
    problem - has funny idle, no throttle responce & no tacho reading.
    occurs/started when - starting the car.
    personal situation - need to fix these before i can drive/register the car
    No tacho: ok so i need to know where the tacho wires are in the engine bay so i can join them into the engine loom.
    Funny idle: it revs up and then down over and over again. see this video.
    No throttle response: it just dose nothing ... i open the butterfly and it just gets louder.
    Veteran Nikkojoe's Avatar
    Tom
    Tps needs setting, and you have an air leak
    Have you wound the idle screw down? Have you done a proper cold start setup, or did you not worry about it and leave the cold start valve under the throttle body still attatched?
    Dave
    do a diagnostic test on ecu. some sort of sensor error.
    mine did that when i first fired mine up, turned out to to be TPS.
    unplug the TPS and see if it helps, it will run pretty good without it (if it is the problem)
    damnit i was beaten by nicjoe!
    - Blaise Pascal
    Veteran slide86's Avatar
    Huw
    Hills
    i can hear that it has a massive vacum leak from somewhere. that would cause teh hunting at idle
    it is revving way to high for idle and by what is happening when you crack the throttle, id say your timing is way to advanced.
    the tacho wire is a black wire that should be on the drivers side, near the strut tower. SHOULD be.......
    Veteran timbo's Avatar
    Tim?
    Wild West
    check your tps, sound similar to mine when the tps came lose and the wings off the throttle weren't moving the sensor. as for the tacho i assume by your comment that it is not related to the engine trouble, as in didn't previously work?
    damn i got to think and type at the same time, you guys are too quick!
    Jul 2009
    Daniel
    Morisset
    ive checked for vac leaks.. the tps sounds more like the problem ... as i moved it a little bit and it and it slowed down the idle a lil... but if thats the problem then that could also explain the no throttle response ... ill try this tomorrow morning.
    Jul 2009
    Daniel
    Morisset
    the tacho hasn't worked when ive owned the car ... but in saying that this is the 2nd time Ive started since Ive owned it.
    so the no tacho part is more a question of wheres the wire ... if someone could provide a pic that would be nice... otherwise im going to go hunting for the wire mentioned above by slide86
    i will also check my timing.
    the cold start system under the throttle body is still there but i have blocked all the pipes off as i couldnt work out where they go ... if someone can explain that it would be nice to ...
    also thanks very much for the quick response to this... i would have to say this is the best response ive had to a tech question so far.
    Tim?
    Wild West
    take it off completely and make sure it goes in properly and tighten the fkn screws up! i have failed with this previously...
    the two pipes that come from under the throttle body are for aircon?
    Jul 2009
    Daniel
    Morisset
    so re-set the position of the TPS? with it unplugged the car will still run yes?
    Jul 2009
    Daniel
    Morisset
    i have 3 pipes under the thottle body ... well 5 actually ... 2 are water contolled and the other 3 are air ... the water ones are connected and the air ones are covered over with duck tape.
  1. Rather Strange problem. 4AGE + idle + tacho
    By Deeken in forum Technical - Questions
    Last Post: 16th November 2011, 06:31 PM
  2. JDM fuel pump/ funny idle on 20v
    By sdrawkcab in forum Technical - Questions
    Last Post: 25th October 2011, 07:10 AM
  3. funny as
    By slidy in forum Youtube Chan
    Last Post: 6th April 2010, 05:56 PM
  4. sr20 throttle body and idle motor
    By tin can in forum Cars or Parts Wanted
    Last Post: 27th August 2009, 03:57 PM
  5. Replies: 6
    Last Post: 13th December 2006, 07:28 PM
