Results 1 to 3 of 3
Thread: 4agze engine mounts (into ae86)
    Veteran 86TRD's Avatar
    Luke
    Forster
    Default 4agze engine mounts (into ae86)
    Car -AE86
    motor -ae101 4agze
    use -track/daily
    problem -how do i go about putting on the 86 engine mount on? the super charger bracket is taking over the bolt and there is also a tab coming off the block which is also in the way. , how do i go about this? can i just cut off the tab?
    any info greatly appreciated.
    cheers,
    luke.
    Veteran Nikkojoe's Avatar
    Tom
    Yep, cut the tab of the supercharger bracket off. There are 3 other bolts holding that bracket on so it wont go anywhere. Some people choose to half moon both the engine mount bracket and the charger bracket, but thats dumb. The engine mount supports the engine so dont modify it
    The other pins can be removed using vice grips or pliers. They are only pressed in.
    Luke
    Forster
    ah sweet , thanks heaps tom.
  1. sr20 into ae86 engine mounts
    By trueno_coupe in forum Cars or Parts Wanted
    Last Post: 3rd October 2011, 01:05 PM
  2. AE86 Stiffer Engine Mounts
    By Patrini in forum Technical - Questions
    Last Post: 28th January 2011, 06:58 PM
  3. AE86 Front Engine Mounts
    Last Post: 3rd January 2010, 08:20 PM
