Results 1 to 10 of 12
Thread: 4age dies when hitting 6000rpm
    Member Alexii's Avatar
    Alex
    Default 4age dies when hitting 6000rpm
    Ive got a 4age and i finally got it running perfect. Now when i take it for a drive and rev it above 6000 rpm its just dies until the revs drop back to 2000rpm and then it will take off again.
    Could this be a spark or fuel issue has anyone had this problem before or know what is going on?
    in the build KE70... whats next?
    Veteran timbo's Avatar
    Tim?
    Wild West
    could be anything.
    everyone will tell you to do a diagnosis test on the ecu, so do that.
    check spark
    check timing
    Veteran slide86's Avatar
    Huw
    Hills
    what was the cause of the previous problem with cyl 3 being out?
    Glenn ke_70's Avatar
    Clay
    Barossa!
    you could be running out of fuel. this happened to my mates turbo 4k his lift pump that supplyed the surge tank couldnt keep up with the motor so it would die about halfway up 3rd then he'd have to back off till the tank filled up again
    Alex
    Hmmm that could be causing the problem. Im running a vl external fuel pump and i wanna double check where would be the correct place to mount the pump?
    I had it inline with the bottom of the fuel tank and it sounded like it was starving for petrol so now i have moved up above in between the tank and the tunnel and now the fuel Pump sounds abit healthier
    Aaron
    hows the pick up for the pump? i would put a fuel guage on it and take it for a drive with someone else to watch it
    Alex
    i thought maybe the fuel tank had shit in it so i pulled it out and cleaned it. still cuts out. could it be fuel pressure?
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    more than likely the case. did you use a second hand VL pump?
    FTP.
    Alex
    yeah came with the engine when i bought it. forgot to mention its a bigport with tvis removed could it be an air intake error/vacuum?
    Veteran Nikkojoe's Avatar
    Tom
    Not likely. Sounds fuel related, possibly spark too (but doubt it very much).
  1. 16v 4AGE dies warm then won't start again
    By Brokenships in forum Technical - Questions
    Last Post: 3rd May 2012, 10:06 AM
  2. 4AGE dies under 3000 rpm
    By grey_nomad in forum Technical - Questions
    Last Post: 7th June 2011, 11:10 PM
  3. whos HITTING it?
    By fantapants in forum Grip and Tarmac Racing Section
    Last Post: 28th July 2010, 10:02 PM
  4. 4age dies when its hot
    By boh in forum Technical - Questions
    Last Post: 27th March 2008, 08:28 PM
  5. 4age farts and dies under throttle
    By Blood Child in forum Technical - Questions
    Last Post: 9th April 2007, 09:56 PM
