HI all
im in Rostrevor sa and i need
1. rwd 4age top water outlet.
2. 4age Top timing cover
HI all
Formerly known as grape_moosha
buy new flywheel bolts.
i have a RWD water outlet (back of head one) if you need one.
how much are new bolts?
do u mean the rwd sensor block? ive aredy got one of them but thanks anyway
anyone know if you can use 4ac water pump??
also i need something else
i need the 2 mounts that mount to the side of the engine quite low down and then bolt to the lower bellhousing
Yes you can, you can even use the rear half/housing of the water pump and corresponding side pipe (which connects to heater) on a 4age. You will need a rwd 4age top outlet, the little bypass pipe that goes between the rear housing, a rwd 4age lower outlet (or the thermostat outlet on the fwd ae82/ae92 remote thermostat) and top outlet and a 4age rwd water pump pulley. You will also need a rwd alternator bracket... OR make your own bracket to sit the alternator lower.
If you just use the front half of the pump you will just need the rwd 4age pulley...
i have the gearbox stays..
Note: When using the 4ac pump on a GE the timing cover hits on the pump as it is not cut away like the GE item.
ok sussed flywheel bolts and gearbox stays.
i have got a 4ac pump but it doesnt fit and id rather just find a rwd setup than stufff around with fabrication.
so in need of a rear wheel drive water setup i have got the sensor block on the back ofn the head, i need waterpump front and rear housing, pipe that goes to the back of the head. top outlet housing and the bypass between the pump and top outlet. also alternater mount if its diff form fwd one
updated first post
Updated first post again
I have the top outlet and a rwd waterpump pulley, pm me if interested.
