Results 1 to 8 of 8
Thread: 4age into ke70 - Wiring question
    Jon
    Durack
    Default 4age into ke70 - Wiring question
    Hey all,
    B4 ppl say research I have.
    I have read a lot of 4age into ke70 threads but my questions is more specific
    What is the best loom to use to wire up the 4age into a ke70? Does the whole ae86 loom work?
    or is there specific parts of the loom you need to wire into the ke70 loom
    Some people have used:
    ae82 loom
    ae86 loom
    when it comes to wiring i honestly have no idea....
    Kieran
    if you have the ae86 (rwd) loom use it.
    Jon
    Durack
    that i do. this was what i was going to do but wondering how much of the loom is not required for a keto..
    looking to have a clean engine bay so less wiring the better
    you need most of it,
    though there is stuff you can get rid of (aircon for example) but it would require untaping the entire loom, stripping out what you dont need, and taping it back up, and then hoping that you didnt strip out something you DO need, and having to do some nice re-doing.
    essentially you need everything in this list for the engine to work
    was this 4age and loom sho-horned into an ADM 86 before? if so the wiring is EXACTLY the same.
    - Blaise Pascal
    Moderator Sam-Q's Avatar
    Endeavour Hills
    an ae82 loom needs to be resized so that the leads run in the correct direction and end up in the right places.
    Jon
    Durack
    wiring has: converted 4ac to 4age and a new horn thats it
    Veteran Nikkojoe's Avatar
    Tom
    In an ae86 loom there is nothing anyway. A/C runs through the body/engine bay loom. The only thing that is extra in the ae86 loom is the wiper motor wiring.....
    AE82 loom is ok to use, has alternator wiring included as well as a/c wiring but it generally goes in the right direction, just a little too long (not always a bad thing).
    AE86 loom is best to use. The firewall plug will need to be changed to suit the ke70 firewall plug (or make a new plug to carry the extra wires of the ae86 loom - ignition and injector power).
    Jon
    Durack
    Thanks for the information guys. i will be paying someone to help me sort out the loom
  1. Ke70 wiring question Help..
    By adds in forum Technical - Questions
    Last Post: 19th May 2012, 08:02 PM
  2. 4age into ke70 wiring
    By Sprinter Freak in forum Sydney & NSW Events and Discussion
    Last Post: 28th November 2011, 03:17 PM
  3. Ke70 wiring diagram - help wiriing 4age into ke70
    By Low Style in forum Technical - Questions
    Last Post: 24th October 2010, 09:06 AM
  4. 4age into KE70 wiring
    By ke70 xx in forum Adelaide & SA Events and Discussion
    Last Post: 8th May 2009, 12:40 AM
  5. Bigport 4AGE into AE86 wiring question
    By Sprinter-Saurus in forum Technical - Questions
    Last Post: 29th July 2006, 07:46 PM
