Car - 1984 SR5
motor - 4A
use - Daily
problem - Carb rebuild help
occurs/started when - Just bought it with a bad carb
personal situation - Picked up a nice '84 SR5 "everything stock except the radio". Carburetor issue sounds like a stuck float, but I'm running to pick the car up in 10 days. So I got this junkyard carb that should be good and am going to give it the once over so I can swap it out and go - hopefully. Has anyone got a step by step for a first timer on the rebuild and swap? The swap looks straightforward except for the wires hardwired into the solenoid etc. It would help to get the assembly order from someone that knows it. I've got new gaskets, nozzles, and such. Hopefully,
Albert
