Results 1 to 10 of 10
Thread: Clutch cable
    Member sidewayz_simon's Avatar
    Simon
    Baldivis
    Angry Clutch cable
    mine is fucked, does anyone know anyone that will fix it without charging me the earth?
    Veteran Todd's Avatar
    Feb 2010
    Todd
    SOR Perth
    ae86's dont have clutch cables dude, they are hydraulic.
    whats actually wrong with the car?
    Simon
    Baldivis
    god dammit i thought they were a cable clutch. theres no pressure in the clutch pedal.cant change gears.
    Veteran Nikkojoe's Avatar
    Tom
    check fluid in clutch master (next to brake master). If empty check for leaks either around the master or the slave or the lines that connect the two. Slave is located on the drivers side bellhousing on gearbox (or just follow the solid line from the master to the end).
    Simon
    Baldivis
    Leaking slave cylinder, fixed.
    Senior Member trueno's Avatar
    Nik
    North side
    ae85 comes with cable clutch.
    AE86 JDM TRUENO
    FULL JDM EP91 GLANZA V (REPLICA)
    EP82 GT TURBO[SOLD]
    EP91 GLANZA [SOLD]
    AE82 FX GT [SOLD]
    S13 SR20DET SILVIA [SOLD]
    Feb 2010
    Todd
    SOR Perth
    ...it's a jdm ae86 zenki trueno GT with hydraulic clutch 4age twin cam engine.
    Site Supporter Javal's Avatar
    Josho
    'sick'
    Feb 2010
    Todd
    SOR Perth
    back to radelaide sir.
    Phirom
    Slightly on topic...I just found all of my spare clutch slave stuff just then. Had an ADM slave and hard line in my storage container.
    But good to hear your clutch probs is fixed.
  1. KE70 Clutch cable
    By starni_boy in forum Cars or Parts Wanted
    Last Post: 23rd September 2009, 03:46 PM
  2. Throttle Cable and Clutch Hard line
    By ke70 xx in forum Cars or Parts Wanted
    Last Post: 8th July 2009, 09:16 AM
  3. clutch cable for a ke70
    By Clinton in forum Cars or Parts Wanted
    Last Post: 12th August 2008, 07:01 PM
  4. Cable clutch to hydraulic conversion
    By Aus-spec86 in forum Technical - Questions
    Last Post: 27th January 2008, 10:30 PM
