Results 1 to 3 of 3
Thread: Air con back into a AE71
    Junior Member QuoKKa's Avatar
    Sep 2010
    Default Air con back into a AE71
    hey guys.
    im new to these cars so i thought il make up a thread so you guys can help me out.
    ive recently done a 4age conversion into my AE71 and i want to put the A/C back into it but my problem is that when i got the car it is missing the air con condenser.
    ive tried calling around for a condenser but no luck so i may have to use a universal one but has anyone else done this before?
    what i was playing on doing is use a fwd 4age air con compressor and find a universal air con condenser and getting someone to make custom lines up for it.
    can i even use the fwd corolla condenser?
    will this work? or does anyone know a better option to go about this
    thanks and sorry if someone has already made a thread up for this!
    Veteran Nikkojoe's Avatar
    Tom
    FWD condensor is too wide (to suit wider fwd body/rad support).
    Senior Member macca1590's Avatar
    Central Qld
    if you can find a condenser that will fit it shouldn't be too much dram to make up custom lines, as long as the inlets/outlets of compressor and condenser are not in too much of a tight spot, if your lucky you might find a ke70 with condenser and some lines that may be re usable at wreckers, like dryer fittings and pressure switch ports ect
  1. ae71 air con stuff into ae86?
    Last Post: 29th March 2013, 01:54 PM
  2. Ae71 heater core and air con unit
    By GrumpyRacing in forum Car Parts For Sale
    Last Post: 25th January 2012, 03:04 PM
  3. SA - AE71 Wagon, 5 speed, Air Con, Rego, Good Condition
    By LukeKE11 in forum Cars for Sale (Toyota Only)
    Last Post: 24th January 2011, 09:26 AM
  4. Air Con. how to remove front air-con cooler safely
    By Ade_Mc in forum Technical - Questions
    Last Post: 6th March 2010, 10:05 PM
  5. Air con Set-up
    By Dish in forum Car Parts For Sale
    Last Post: 21st February 2008, 10:06 PM
