Results 1 to 10 of 19
Thread: Steering wheel vibrating at high speeds
    Dim
    Menai
    Default Steering wheel vibrating at high speeds
    Car - 1985 ADM Toyota AE86
    motor - 4-AC Power
    use - I drive it erryday
    problem - When travelling around 8km/h and over sometimes the steering wheel tends to vibrate, not to the point where the car is uncontrolable, but I feel it's something I should be concerned about.
    occurs/started when - Well it was happening before I put new wheels & tyres on, and even after I got a wheel alignment.
    It happens sort of randomly, or I havnt found a pattern at least, usually the slowest speed it might happen is 80, but sometimes depending on the amount of throttle it doesnt vibrate.
    personal situation - I feel like it's something I should check out, but I don't know who or what to blame and consequently who to take it to to fix it.
    Member khoala's Avatar
    Khoa
    did you get a wheel balance when you got the wheel alignment?
    Gunner
    yeah dude, the clowns haven't balanced your wheels. You go to that place just down prom pulse? please say no, cause they are a bunch of fuckwits.
    Dim
    Menai
    Nah I got it done at a place in Kingsford, my dad took his falcon to tyrepower, that was a mistake.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    too much caster
    FTP.
    Gunner
    on a somewhat stock 86? he only just put wheels on it.
    Akio
    Mt Haruna
    Japan
    more likely worn out bushes.
    but too much toe out, worn ball joints, worn out steering rack/arms, loose suspension components will also cause this.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    If your not sure, most suspension places will do a FREE check for you, and will tell you whats old and fucked....... It will cost nothing
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Don't forget to check wheel bearings.
    Andrew
    Glenn ke_70's Avatar
    Clay
    Barossa!
    what wheels have you got?
  1. Replies: 3
    Last Post: 29th November 2011, 08:20 PM
  2. Replies: 5
    Last Post: 18th April 2011, 03:56 PM
  3. steering wheel, boss kit and slip on wheel spacers :) (SA)
    By robert84 in forum Car Parts For Sale
    Last Post: 2nd September 2010, 06:28 PM
  4. Replies: 5
    Last Post: 28th July 2009, 09:54 PM
  5. Wheel Alginment issues and vibration at high speeds.
    By lok19 in forum Technical - Questions
    Last Post: 1st October 2006, 01:42 AM
