From memory, you need the whole AE71/86 crossmember. I dont think just using 4A mount with a Ke70 Xmember will work. Can someone confirm this?
Hey just wondering if someone can tell me if ae86 engine mounts fit into a ke70 cos im dropping a 4a 20valve into it . I know that ppl use ae71 ones for ke70's. Want to get some new cusco ones because second hand ones might be worn out
mounts on crossmember are wider apart on the ae71/ae86 crossmember, the rollaclub knowlegebase/ faq section has a picure comparing the two.
the KE70 onea are also higher and have a notch sticking out.
You need an ae71/ae86 crossmember. You can keep your steering rack though.
thanks people much appreciated ^_^
