Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 11 to 20 of 47
Thread: AE and KE Rear coilover questions
  1. #11
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Glenn ke_70's Avatar
    Clay
    Barossa!
    yeah im hearing ya but... id really like to the feature of using removable inserts. in case i need to replace anything or more importantly i can use different shocks if i want to.
    wouldnt a rose joint be better anyway? not for street but for the track.
  3. #13
    Veteran shift_rook's Avatar
    SE Burbs
    in the way of performance for a damper not a huge difference, just get a serviceable/ take apart damper, getting an insert will be no different, instead of binning a roll closede shocfk you throw away the insert, buy something that can be pulled down. i.e bilstein damper
  4. #14
    User fantapants's Avatar
    Pat
    ur over thinking it clay......
    check out the t3 setup... it can definitly be improved upon, but its a great starting point.
    06/07/2011
  5. #15
    Pat
    oh yeah and a lttle bit of orange juice came out my nose at that
    06/07/2011
  6. #16
    Clay
    Barossa!
    yeah but what im thinking isnt really overly complicated really.
    the t3 kit is essentually what im making but with a tube housing instead of just a slip over sleeve.
  7. #17
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the problem is there normally isn't enough room for a conventional 65mm spring between the body and the wheel.
  8. #18
    Clay
    Barossa!
    oh i hadnt considered that sam.
    ive pretty much desided to go for some euro build coilovers that are actually alot cheaper than i thought.
    thanks for the help everyone
  9. #19
    Endeavour Hills
    oh thats an interesting option, hey keep us updated ok?
  10. #20
    Clay
    Barossa!
    sure will sam thanks.
  1. White line ae/ke rear sway bar ajustable
    By timpy in forum Car Parts For Sale
    Last Post: 7th January 2013, 09:27 PM
  2. BRIS - ae/ke rear bar. Dished rims! Diff LSD
    By schubey in forum Cars or Parts Wanted
    Last Post: 16th February 2010, 07:57 PM
  3. KE\AE rear coilovers. What fits?
    By Skid_KE70 in forum Technical - Questions
    Last Post: 31st January 2009, 01:10 AM
  4. WTD STD rear Sprinter springs AE or KE
    By Clemo55 in forum Cars or Parts Wanted
    Last Post: 9th May 2008, 11:36 AM
  5. rear shocks ae to ke
    By dunga70 in forum Technical - Questions
    Last Post: 4th March 2008, 07:52 AM
