Easier to find and utilise! Using an ae92 map loom with correct ecu (ae92 map) you will need a 4agze cas OR ae92/3 adm or jdm smallport dizzy at minimum. I may have a smallport dizzy if you end up needing it. You can't use the dizzy you have now because:
1. it aint stock, all the original shit has been gutted in it and an custom pick-up has been used.
2. even if it was still all the factory shit inside, its a 24/4 dizzy by nature which does not work with a gze, only a bigport 4age (which skylar has pointed out a few times)
Gze setups are picky, cant slap shit together and hope they work ok. Really need to retain a lot of the factory stuff for them to work at their best, which is sometimes why when people go aftermarket ecu on them there are no gains (sometimes steps backwards!).
