Results 1 to 10 of 14
Thread: AE86 Front Wheel Bearings
    Senior Member Deeken's Avatar
    Jan 2011
    Deeken
    Port Macquarie
    Default AE86 Front Wheel Bearings
    Hey guys, just about to get some brakes for my 86 coilovers and the bearings I got with the hubs I got told were shot. So I've decided to buy brand new wheel bearings and assemble everything together and bang em into my car, was just wondering if there is any differences in any of the 86 year models in terms of the bearings?
    I found these on ebay and was thinking of buying them;
    Cheers,
    Deeken.
    Veteran AJPS's Avatar
    Lonsdale
    you can get cheaper local
    they are all the same (to answer your question)
    Jan 2011
    Deeken
    Port Macquarie
    For my other corolla i used to have (ke70) I got quoted like $38 a side or something for front ><
    Veteran Nikkojoe's Avatar
    Tom
    I just bought a wheel bearing kit from auto1 about a month or two ago. Cost around $30 per side (includes inner and outer bearings, plus a new hub seal ring).
    Veteran slide86's Avatar
    Huw
    Hills
    $50 for both sides........brand new
    I have a spare set here that im not using if your interested
    Veteran timbo's Avatar
    Tim?
    Wild West
    i just hit up repco. the box said they were from china but the bearings were stamped japan! win! so check out repco and have a look at the bearings before you buy them.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    if you go to repco make sure to take the shot ones with you as a sample as they are hopeless
    Veteran johl's Avatar
    Johl
    when you guys pulled the rotors off the hub to get to the bearings did you have any trouble? i have undone the 4 bolts holding the rotor to the hub and i still cant get it off. have hit it with a massive hammer but i was wondering whether you need to heat it up to get it off?
    Huw
    Hills
    they are tight as hell sometimes. you will probably need to get a large flat head in between the two, too prize them apart.
    you dont need to pull the discs off the hub to get the bearings out tho......
    Johl
    yeh i know but im putting my wilwoods on. thanks i'l cover it in some sort of penetrating fluid and give it a crack
  1. Replies: 1
    Last Post: 6th September 2012, 12:12 PM
  2. JDM front wheel bearings
    By northy in forum Technical - Questions
    Last Post: 5th July 2012, 09:29 PM
  3. front wheel bearings and rear disk rotors
    By .ady in forum Technical - Questions
    Last Post: 26th July 2009, 11:54 PM
  4. Wheel bearings
    By daz in forum Technical - Questions
    Last Post: 17th April 2008, 10:57 PM
  5. Koni Spring Top (Coilover) and Front Wheel Bearings
    By thanhngo in forum Car Parts For Sale
    Last Post: 25th March 2007, 10:13 AM
