Results 1 to 10 of 19
Thread: AE101 4agze Compression test results
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    Default AE101 4agze Compression test results
    i just did a comp test on my GZE an came up with near 170psi across all four which is pretty good i believe, i want to know the toyota factory results to compare if the motor has had some work done to it, or if its low in compression.
    ~KEEP DRIFTING FUN~
    Stern but now fucked off...
    May 2005
    Nick
    AFAIK 140-150 is fairly standard
    Mereki
    Badassville
    thanks nick, so in saying that, there maybe aftermarket pistons in it?
    ~KEEP DRIFTING FUN~
    Veteran Nikkojoe's Avatar
    Tom
    140-150 for a bigport gze
    170-180 for a smallport gze
    May 2005
    Nick
    smallport gze?
    Mereki
    Badassville
    ah ok so its all good then, makes me happy. yeah nick 101 gze's are smallport
    ~KEEP DRIFTING FUN~
    May 2005
    Nick
    Sorry, I meant to say weren't all GZE's smallport?
    Ok
    Seamus
    Milton
    bigport gze = MR2 = kinda AIDS
    smallport gze 1 = ae92 = pretty good, lower comp 8.0:1
    smallport gze 2 = ae101 = awesome win, higher comp 8.9:1
    awesome results trikzlane
    ^ Clicky clicky!
    Mereki
    Badassville
    aw11 is bigport with dizzy
    ae92 is a smallport CAS
    ae101 is also a samllport with high CR then ae92 (also CAS)
    ~KEEP DRIFTING FUN~
    Mereki
    Badassville
    YAY, all is good, now to abuse it hehehe
    ~KEEP DRIFTING FUN~
  1. Blacktop Compression Test Results
    By Matt in forum Technical - Questions
    Last Post: 4th August 2010, 02:44 PM
  2. Compression Test
    By SNAP in forum Technical - Questions
    Last Post: 16th June 2008, 09:56 AM
  3. Bench Compression Test
    By Gilly in forum Technical - Articles
    Last Post: 9th May 2008, 04:11 PM
  4. compression test
    By albertos in forum Technical - Questions
    Last Post: 17th June 2007, 11:19 PM
