Results 1 to 4 of 4
Thread: 4AGTE issue - Engine is boosting fine, but revs are slow to pick up
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Default 4AGTE issue - Engine is boosting fine, but revs are slow to pick up
    Car: AE86
    Engine: 4AGTE (T25G)
    Here is my query....
    After my last hillclimb competition round, I noticed the car didn't seem it's usual self when I was driving home from the event.
    The engine doesn't seem to be picking up the revs as quick as it was before, but the boost levels are normal.
    Ie; as I drive along, it boosts normally to 15psi, but the actual engine revs (from 4000rpm onwards) does not speed up as quick as it used to. I makes a new noise too. When the boost is getting high, it's making sort of like a BOV (ssshh) sound, before I have backed off the throttle, yet no sign of it on the boost guage. The actual BOV then works as normal when I back off the throttle.. It's NOT blowing any smoke either
    I Have never had blown turbo before, so I dont quite know what to expect if it was that. But I wouldn't imagine a blown turbo would even produce any boost at all tho???????
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    vacum leak, boost leak, exhaust gaskets, faulty wastegate or BOV acuator
    ~KEEP DRIFTING FUN~
    Jason
    Southern Suburbs
    Boost leak, compressor outlet temp high because turbo trying to compress too much air (ie out of effecient range), lack of power from high air inlet temps?
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Check all your joiners on your cooler piping. Seems strange that it will reach normall boost pressure if it is leaking, unless there are a couple of very small splits/cracks that only really open up at 15psi.
  1. Engine build issue: CAS shaft hitting ARP head stud
    By maxhag in forum Technical - Questions
    Last Post: 2nd January 2012, 12:09 AM
  2. Fresh 4agte engine.
    By --Redwork-- in forum Car Parts For Sale
    Last Post: 16th May 2011, 01:37 AM
  3. 4AGTE Engine Package
    By blinded in forum Car Parts For Sale
    Last Post: 8th November 2010, 08:26 PM
  4. engine management issue
    By x_christ0n in forum Technical - Questions
    Last Post: 14th September 2010, 07:18 PM
  5. Team Fine 300hp 4AGTE AE86 Trueno
    By PeakingDuck in forum Offtopic Discussions
    Last Post: 25th December 2009, 01:04 PM
