Bump
For sale:
1. AE86 struts with standard shocks, calipers, rotors and spring hat, suit xE7x upgrade (requires ae86 non p/s or p/s arms)
3. Standard adm springs
4. Kyb excel-g normal stroke shocks
5. Standard adm 86 rear shocks
6. xE7x Strut tops, give you slightly more caster over ae86 strut tops
7. AE86 adm strut tops
8. 4AC starter motor
9. 4AC flywheel with clutch and pressure plate
10. FWD 4AGE 5spd gbox
11. FWD 4AGE throttle body
12. FWD 4AGE Intake manifold
13. FWD 4AGE exhaust manifold
14. 4AC Coil
15. 4AC Clutch fan
16. 4AC Alternator
17. Complete standard 86 exhaust
Item Condition:
1. Shocks worn, but the rest is all vgc (pads have plently of life left)
3. Standard adm yo
4. Good working order, were going to be put in struts no time to do so
5. Good, still work fine, comes with bushes and nuts
6. Good
7. Good
8. Was working before removed from car (4age starter took it's place)
9. Clutch worn, rest is good
10. Unknown condition, came with working motor
11. Can come with tps that has broken mounts, works fine
12. Good condition, needs a clean, comes with tvis and all sensors (MAT sensor might be dodgy)
13. Good, comes with heat shields
14. Worked in my car fine, comes with resistor (if I can find it)
15. Seized bearings meaning it's constantly spinning, keeps car ultra cool but very noisy at high rpm
16. Works, but dirty
17. Poor but can be fixed if you have welding tools
Price and price conditions:
1. $100 pair (firm - no seperating - PERTH PICK UP ONLY) ON HOLD
3. $10 set
4. $70 pair SOLD
5. $10 pair
6. $10 pair
7. $20 pair
8. $10
9. $5
10. $50? (make an offer)
11. $40
12. $40
13. $20
14. $10
15. $5
16. $10
17. Removed from sale (now to be thrown out)
Extra Info:
Pictures:
Pedders springs not shown
Contact Details: Pm or post in thread
Delivery & Conditions of Delivery: Will post at buyers expense (items less than 15kg and not large and bulky)
Bump
Im interested in the adm rear struts and xe7x strut tops...but the big q is will you post at my expense.
Thanks Ben.
I may post them out depending on if i get time to do so. Ill let you know either way![]()
Bump
Bump
Do you know if the 4ac starter will work in a AE92 Seca SX (4age)?
Not sure, but I found a thread on here the other day about different starter motors, so a search may reveal it.
Bump
Bump
Bump, need stuff gone
