Results 1 to 10 of 14
Thread: oil cooler sandwich plate for 4ac
    Aaron
    In the Mountains
    hey,
    I heard a rumor that a 4age oil cooler sandwich plate will fit straight in on a 4ac is this correct? if it dose would I be correct in thinking that other sandwich plates that suit 4ag would also fit 4ac (16v ones)?
    I would really rather one that had a inlet and outlet on the sandwich plate as I'm not keen on drilling my sump for a return line, dose a standard one have inlet/outlet on the plate?
    also would a drop in oil small drop of oil pressure due to the oilcooler be harmful?
    thanks, there has been a lot of questions in the past about oil coolers etc I know, I got a lot of results on my search, but I didnt get the answers if was after.
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    don't think anything that fits on 4age would fit on 4ac, as the 4ac oil filter (and there for the port) is a lot larger.
    My sandwhich plate is straight off a 20v, so it would also be vice versa if thats one of your questions.
    Hope that helps a little
    Elite rthy's Avatar
    Leo
    Tulla
    get one of those aftermarket ones
    Aaron
    In the Mountains
    so thats a no go on the 4age/4ac being the same?
    I want to pay as little as possible alsong is has and inlet and outlet on the plate.
    anyone recomend a brand/model I wonder if they would even make one for 4ac... possably in america
    edit*must be cheap as possible, just needs to be that^^
    Veteran biggo's Avatar
    Nick
    Noosa
    a sandwich plate is just that, it get sanwiched between the oil filter and block. FYI most aftermarket oil cooler kits come with a 3/4" metric hole which fits toyota/nissan/ford/holden
    also a 4ac wont need an oilcooler.
    oh yair and it's winter!
    I'd be very suprised if 4AC and 4AGE oil fittings were different. Though I can't check til this evening. Maybe someone could cross reference the filters used.
    Only the factory bypass cooler returns to the sump. All (ok, most) aftermarket setups use a full flow cooler.
    Aaron
    In the Mountains
    not what I asked was it..? I wasnt asking for opinions on where is was nessesary. yes I know it's winter, I also live in tassie. just preparing for summer. I'm also going to be doing more track days and continuing with my hills work.
    thats what I thought, I would check myself bu I don't have a sandwich plate handy and I don't know nayone who would or I would do this myself
    that would be good if you could check for me.
    Jonathan
    I have to disagree with v-tech.
    A standard oil cooler sandwich plate from a AE82 or AE95 or AE92 corolla will fit a 4A-C. To use this you also need a return hole in the sump. You are best to take the sump off, drill a big hole, and weld a nut to the inside of the hole.
    Otherwise use a full flow aftermarket sandwich plate.
    A Z386 oil filter will fit almost every Toyota car.
    Dave
    The Ghetto
    early 4age and 4ac are same block no reason why it shuldnt fit
    Veteran Nikkojoe's Avatar
    Tom
    I removed my standard adm sandwich plate on my ge cause I did not have a cooler at the time. I un-screwed the oil filter/sandwich plate fitting bolt, and removed the sandwich plate. I then unscrewed the 4ac oil filter fitting bolt and fitted it to the 4age. Then blocked up the return line with a closed bit of hose. Therefore, in answer to your question yes it will fit.
  1. 20v Oil Cooler Sandwich Plate
    By sonsta in forum Car Parts For Sale
    Last Post: 22nd April 2009, 11:55 AM
  2. Earls oil cooler sandwich plate
    By Jonny Rochester in forum Technical - Questions
    Last Post: 8th June 2008, 12:00 AM
  3. 4age oil cooler sandwich plate
    By HiLtOn in forum Car Parts For Sale
    Last Post: 3rd October 2007, 09:06 PM
  4. Earls Sandwich Plate For Oil Cooler Set Up
    By aeke7086 in forum Car Parts For Sale
    Last Post: 16th June 2007, 11:39 AM
  5. WTB sandwich plate for oil cooler
    By aeke7086 in forum Cars or Parts Wanted
    Last Post: 9th January 2007, 05:51 PM
