Results 1 to 10 of 13
Thread: fuel pressures
    Dec 2006
    sup, just a quick question, what fuel pressure would be right for a stock smallport 16v, (extractors tho). cheers guys
    stefan
    vic
    eastern suburbs
    I had mine set at 18-20psi when I had the malpassi fuel regulator on my car. could never get decent economy so I stuck the stock one back on
    Dec 2006
    yeah I'm just lookin for reasons why it wont start atm, and sceems to piss fuel out the exhaust, so I just whanna know what fuel pressure to set it to.
    Veteran slide86's Avatar
    Huw
    Hills
    if there is heaps of fuel coming out the exhaust, id be looking at no spark issue.
    also, the plugs will be fouled to shit if there is that much fuel going through the engine
    Dec 2006
    it's got spark, just dosent sceem to have a verry big spark, plugs are rite and have 1.1 gap, but I duno, as soon as I put the 02 sensor back on, it leaned out and fired more, still didnt kick over and run tho,,,,,any sugestions now or?
    Veteran biggo's Avatar
    Nick
    Noosa
    4age 16v's have a .8mm gap don't they? my gze does.
    give the plugs a clean with some tie wire and get it right down the bottom. my gze fouls plugs like this weekly lol.
    also bt20v fuel pressure is something like 38 pound.
    Dec 2006
    anyone comfirm the gap is .8 mm?????
    ill look on that 4age site anyways
    Apr 2005
    new plugs! check leads!
    something sounds funny there.
    Veteran Nikkojoe's Avatar
    Tom
    I spent a few days after my conversion trying to figure out why my car was not running (it would start and fire then stall, very weak spark). Got new leads and all worked well
    Jonathan
    Fuel pressure would be around 35-40psi. Spark plugs come gapped at either 1.1mm or 0.8mm. Either will work fine. If the plugs are all black or rounded over, get new ones.
  1. Fpr working pressures, 4age vs 4agze
    By willa in forum Technical - Questions
    Last Post: 14th November 2011, 11:15 AM
  2. TRACK & HILLS TYRE PRESSURES for grip
    By AIROCOBRA in forum Grip and Tarmac Racing Section
    Last Post: 2nd June 2010, 04:58 PM
  3. oil pressures pplz, whats normal for a bigport
    By eightsixboy in forum General Topics (No Technical Questions)
    Last Post: 27th September 2007, 04:21 PM
  4. boost pressures
    By kouki in forum Technical - Questions
    Last Post: 7th May 2006, 01:16 PM
