So I've finally decided to get rid of all my AE86 stuff now that I have an AW11 MR2 to focus my attention on.
All items are located in Wollongong, NSW. Pickup is preffered, however I can post some of the less bulky things via AusPost (ie less than 20Kg).
Prices are negotiable, and this FS thread is also posted on Toymods.
Please contact via thread or PM.
Coilovers:
Strut Legs/Coilover purchased from CVAP - stripped from an ex-Jap Levin. Steel Coilover Sleeves + alloy perches/lock rings.
King Spring 350lb/in 250mm free length 60mm ID (KPS-044) Springs.
KYB AGX MR2 Front 4-Way Adjustable Shocks - KYB P/N: 765015 + 20mm Spacer.
Cusco Pillowball Camber Plates PN: 116 410 A.
S4 RX7 (FC3S) 4piston brake conversion, 1/2" steel caliper mounting bracket, uses FC Rotors (276x22mm). Calipers rebuilt less than 2000Kms ago by Dapto Clutch and brake - new piston seals.
Braided Stainless brake lines (BrakeQuip ADR legal lines)
Race brakes RB74 Pads with heaps of meat left (pictured) + spare Ferodo Road pads.
Nice Products 3" Long Wheel Studs.
Bump-stops.
This is a well sorted suspension and braking package for the front end of an AE86. There's a little bit of surface rust on the discs as they have been in storage for a while. $1500 SOLD
Front and rear Adjustable Swaybars
BTF35Z - 24mm Front Bar Adjustable. All Bushes and mounting hardware.
BTR25Z - 18mm Rear Bar Adjustable. All Bushes and mounting hardware.
Found these to make a MASSIVE difference to the way the car handled - and the adjustment was great for dialling the oversteer in or out of it (for the track and hill...) $250 the pair or $140 each SOLD
Adjustable Panhard rod - all bushes included. $70 SOLD
JDM A86 Brakes - Calipers, Rotors and Front Hubs and Mountings/Dust Shields. $250 SOLD
KYB AGX Rear Shocks - Short Stroke Camaro 8-way adjustable. KYB P/N:743019. These have had less than 2000kms use. As new condition. Best shock available (bar the Tokico HTS - which is now discontinued) for the rear of an AE86. $300 for the pair.SOLD
KYB Excel-G Front Strut inserts - Stock Length. KYB P/N:365015. These have had less than 5000kms use. Replaced when coilovers installed. Good shocks for non-short stroke application. Comes with gland nuts and new top nuts to suit. $80/pr
AE86 Front Strut Legs. Ideal for standard replacement or coilover conversion.$150
AJPS Front Springs 6Kg/mm 235mm Free height. Very little (if any) use. Changed to coilovers just after I bought these. $100SOLD
AJPS Rear Springs - 2 sets - Both 4.5Kg/mm one set to match fronts (I ran these with the coilovers with great success) 260mm Free height. Other set very low suit very low coilover front end. $100 per pairBOTH SOLD
Stock Rear 4-Links. Comes with Prothane Urethane bushes installed. Less than 2000kms use. $100 for all 4.SOLD
15/16" Master Cylinder - Nissan Navara - bolts direct to AE86 Booster. Wiring changed to suit AE86 loom.$50 SOLD
AE86 Stock Booster $30
