im doing a 4ac - 4ag conversion, i found the clutch line touchs extractors, what u do with that?
eason
eason
Some ppl have a fitting made up with a bend in it to steer it clear of the exhaust. Or get a jdm bellhousing which moves the clutch slave to the other side of the car. You will need to modify your hardline and get a new clutch slave from a t18 (te72) if you choose the bellhousing route.
you need to use a longer clutch hose with a banjo fitting on the end, that will miss it. take the short line to pirtek etc and explaing what you want to do.
thx guys
roadsailing, do u hv a pic of that setup?
i have a jdm bellhousing and shifter can send for $200
Most people have this problem when using TRD copies (like me). I got a brake shop to make me a braided line with a normal fitting on one end, and a banjo fitting on another (pointing the hose straight up and over the extractors). A 40cm line should do the trick nicely, costing around $100 (cheaper if non braided, but fittings cost most). I think i have a pic somewhere which ill post up soon.
really appreciate. need my car going by end of this week
Looks like the line is close to exhaust, but just perspective of pic taken
If you go to a brake shop first thing in the morning, with your old sample line, they can make you one up in less than 1hour![]()
thx a lot mate. another thing is does the rubber on the clutch slave got melt down by the heat from the zorst?
hv u had any issues with this setup?
