Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: clutch line touchs extractor
    dean
    victoria
    mildura
    im doing a 4ac - 4ag conversion, i found the clutch line touchs extractors, what u do with that?
    cheers
    eason
    Thurston
    Vic
    North East
    Some ppl have a fitting made up with a bend in it to steer it clear of the exhaust. Or get a jdm bellhousing which moves the clutch slave to the other side of the car. You will need to modify your hardline and get a new clutch slave from a t18 (te72) if you choose the bellhousing route.
    Will
    you need to use a longer clutch hose with a banjo fitting on the end, that will miss it. take the short line to pirtek etc and explaing what you want to do.
    dean
    victoria
    mildura
    thx guys
    roadsailing, do u hv a pic of that setup?
    dean
    victoria
    mildura
    May 2010
    Jason
    i have a jdm bellhousing and shifter can send for $200
    Veteran Nikkojoe's Avatar
    Tom
    Most people have this problem when using TRD copies (like me). I got a brake shop to make me a braided line with a normal fitting on one end, and a banjo fitting on another (pointing the hose straight up and over the extractors). A 40cm line should do the trick nicely, costing around $100 (cheaper if non braided, but fittings cost most). I think i have a pic somewhere which ill post up soon.
    dean
    victoria
    mildura
    really appreciate. need my car going by end of this week
    Tom
    Looks like the line is close to exhaust, but just perspective of pic taken
    If you go to a brake shop first thing in the morning, with your old sample line, they can make you one up in less than 1hour
    dean
    victoria
    mildura
    thx a lot mate. another thing is does the rubber on the clutch slave got melt down by the heat from the zorst?
    hv u had any issues with this setup?
  1. SA: AE71 Clutch master + clutch slave and line.
    By KSUP71 in forum Car Parts For Sale
    Last Post: 10th November 2011, 12:45 PM
  2. wtb: clutch slave cylinder and clutch line
    By 15LIDE in forum Cars or Parts Wanted
    Last Post: 30th June 2010, 04:31 PM
  3. Melb: Pedal assembly, hard clutch line and clutch master
    By stahlz_ae86 in forum Car Parts For Sale
    Last Post: 31st March 2009, 07:04 AM
  4. clutch line
    By lewwy in forum Technical - Questions
    Last Post: 17th August 2007, 10:13 PM
