Results 1 to 7 of 7
Thread: Throttle Cable To Suit 86 Pedal
    Hey all,
    Im chasing (or would like to know if any are available) a throttle cable approx. 500 - 600mm longer than the standard AE86 one. So i'd say it needs to be (im at work and havent looked at it!) about 1m in length and to suit the 86 pedal.
    Are there any other cables from cars around this length?
    Any help most appreciated, Cheers
    Veteran driftism's Avatar
    Andrew
    Watsoia
    ke70 is the easiest, more than enough length for what you need.
    <div class='quotetop'>QUOTE (4AGE - 86 @ Oct 31 2007, 09:54 AM) </div>Definately got enough length, needs to be atleast 500mm longer than standard ae86...??
    If so, thanks!
    Andrew
    Watsoia
    hmm
    it should be close... to connect it to a normal 4age plenum you have to loop it around quite a lot of stuff.
    Veteran Nikkojoe's Avatar
    Tom
    Yep, ke70 i would say. Its around 3 times the length of an adm 86 throttle cable (due to the fact that a K series motor has the carby on the other side of engine bay).
    Aaron
    Vic
    Ballarat
    An AE82 one may work, its a bit longer that the std AE86 one and fits the ae86 pedal with a little modification.
    Ferny Grove
    KE70 cable is being used in this pic
  1. throttle cable
    By blake. in forum Cars or Parts Wanted
    Last Post: 16th August 2010, 08:21 PM
  2. throttle cable
    By trikzlane in forum Technical - Questions
    Last Post: 23rd December 2009, 01:32 AM
  3. Throttle Cable
    By AEA-386 in forum Technical - Questions
    Last Post: 6th February 2009, 08:58 PM
  4. throttle cable
    By kaneO in forum Cars or Parts Wanted
    Last Post: 15th November 2007, 08:08 AM
  5. Throttle Cable
    By WaLLY in forum Technical - Questions
    Last Post: 17th December 2005, 05:45 PM
