Results 11 to 20 of 28
Thread: TODA for my car
  1. #11
    yep thats the one riojin
    where do u buy this penrite fully synthetic 5w-60? autobarn?
  2. #12
    Ok
    Seamus
    Milton
    and when running the car in, always use 100% mineral oil (not synthetic)
    let the car idle for 20 minutes, then change the oil and filter, again to mineral
    and another oil change after 500 or so k's
    you'd be very suprised to see, even on a "perfectly clean" motor how much metal and assembly lube comes out in your oil changes
    ^ Clicky clicky!
  3. #13
    Veteran Konakid's Avatar
    Henry
    Eastern
    <div class='quotetop'>QUOTE (Nikkojoe @ Nov 8 2007, 01:16 PM) </div>Worn Valve seals cause blue smoke, not piston rings
    [/b][/quote]
    Im almost certain that its rings...
  4. #14
    Aaron
    In the Mountains
    im not sure what motor you have in the car now..?
    do you have the 20v in or do you mean its going in..?
  5. #15
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    20V blacktop is in the car, just needs rings changed to blow less smoke (as well as a general service, as mentioned above the car spent 4+ years without an air filter :lol: )
    Yes that is the one that was on Carsales, the first 20V engine conversion that Kaizen did
    Yeah I was on the Nebo cruise, I was right behind Glenn when he introduced himself but I may have been distracted. I don't think you were part of the group that was with the popo, that was where we all got split up she still go alright? We need another cruise so Glenn and I can see it again
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
  6. #16
    riojin
    you can get the penrite 5w-60 at any supercheap auto or other such store. you can get it ordered at different parts specialists/suppliers.
    are you rebuilding your engine yourself or getting it done? if you are getting it done theyll run in the engine themselves with special "run in" oil. listen to what they say to do for the first 5000-8000km and then change to the penrite.
    the engine should have gone through run in oil, swap to mineral, mineral oil change at 500-1000km, another oil change when you get up to 5000-8000km but change to synthetic.
    i personally like to drive the car lightly for the first 1000km and then after a oil change i like to drive the car like i usually would.
  7. #17
    Veteran Nikkojoe's Avatar
    Tom
    <div class='quotetop'>QUOTE (KonaKid @ Nov 8 2007, 03:51 PM) </div>Worn Valve seals cause blue smoke, not piston rings
    [/b][/quote]
    [/b][/quote]
    Probably both, but white smoke is caused by worn rings
    Compression test ftw....
  8. #18
    Senior Member SLO-030's Avatar
    Ryan
    Southern 'burbs
    Compression test wont show anything sometimes.
    Just because an engine is smokey doesnt mean that it is low on compression. It can still have fine compression rings but have rooted oil rings.
    If its smokey taking off from lights or at start up its a good sign that its valve stem seals.
    If its while driving alone its a good sign of oil control rings
    bass_2000_au_au@hotmail.com says:
    they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
  9. #19
    Tom
    <div class='quotetop'>QUOTE (Craig_AE86 @ Nov 8 2007, 10:23 PM) </div>Wasn't saying anything about low compression. Doing a compression test to get base figures, then squirt a little bit of oil into combustion chamber through the spark plug hole, then repeating the test again. If it reads higher the second time, rings are worn (or piston/cylinder damage).....
  10. #20
    Henry
    Eastern
    <div class='quotetop'>QUOTE (Craig_AE86 @ Nov 8 2007, 11:23 PM) </div>Is that the Fours and More diagnosis?
  1. TODA dealer???????????
    By DODGENG in forum General Topics (No Technical Questions)
    Last Post: 20th February 2012, 09:06 PM
  2. Replies: 15
    Last Post: 19th May 2011, 12:58 PM
  3. TODA 4age flywheel
    By todd in forum Car Parts For Sale
    Last Post: 15th July 2009, 02:37 AM
  4. Toda itbs
    By damo46 in forum Technical - Questions
    Last Post: 22nd April 2008, 07:38 PM
