Where is the boost line tapped into?
i do have a boost guage. it reads in the INHG zone for the vaccum when idle. 1 PSI = 0.49 INHG approx. it reads at 22 INHG at idle which is about 11 PSI. when i rev the engine it goes up progressively and when im about to shift at 6000rpm its usually in the PSI zone at 3 PSI. i dont think its reading correctly because i feel the boost even at low revs.
im currently after an omori boost guage as a replacement (im a perfectionist and want all my guages black with green lighting...) which reads in Bar and has no vaccum readings.
i dont know. i know where the connection is but i have absolutely no idea what part of the engine it is.
heres a pic
[attachment=196475000342.jpg]
If the green thing is your map sensor (next to yellow writing at the top of pic), then it looks to be hooked up correctly.
Lol, yours looks like a big mess hahaha (my gze seems soo simple).
well if its hooked up correctly then it must just be the gauge (or maybe my charge just isnt working....)
had a drive just then to check out the gauge. it went up to 4psi. that seems a little low seeing its supposed to be at 8psi@4000rpm at stock.
hmmmm not very happy. im hoping its just the gauge and not the charge thats faulty
