Results 1 to 9 of 9
Thread: Oil cooler question
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    hey,
    Iam installing an oil cooler on my GTE, and i have DASH 10 lines and fittings. Coming from a duel outlet aftermarket oil filter sandwich plate.
    I havent installed it yet, but the DASH 10 lines look pretty big. Will this affect the pressure of the low pressure oil system?
    i know i should add about 1L more oil.........
    All those speedflow fittings cost me a packet!
    What are other people using?
    J Riftin
    Ferny Grove
    Dash 10 seems to be the common size
    my oil cooler setup uses Dash 10 also. I am yet to install it but have faith it will be o.k. worth installing a pressure guage in your sandwich plate (most have provisions for this) to keep a good eye on it.
    I actually have a question that is sort of relevant.
    when you have installed a thermostatic cooler and start the car for the first time, once it reaches the required temp for the thermostat to open there will obviously be a massive pressure drop whilst the pump fills the lines, i will be pre fillling the cooler as best i can but am concerned at the drop in pressure as the lines are quite long and as mentioned above the hose size isn't exactly small.
    any way around this or is it a non event??
    JoJo
    ACT
    Tuggeranong
    thats a good thought...... :unsure:
    JoJo
    ACT
    Tuggeranong
    also,
    Which way does the oil flow through the oil filter? ie. Does the oil go INTO the filter through the middle hole or is that the exit (back to the engine) hole?
    Why i ask, is that iam thinking of mounting the oil cooler SIDE ON, and i dont want the oil working against gravity, ie Pushing up the cooler......
    Any advice?
    J Riftin
    parrot
    Go here
    They are the oil cooling experts, and download the catalogue which has lots of tips about fitting issues.
    Gilly, pre priming is a very good idea.
    Think auto recommended -08 line for me. I am using pushfit fittings which made making your own hoses very simple.
    For a 1600cc NA engine in Australian conditions they also recommended a 13 row cooler.
    The filter take offs are designed so that oil enters the filter via the outside surface then returns through the middle, which is obviously how engines are designed also.
    [attachment=19725:IM000493.JPG]
    There is a metal bracket on the other side, not just zipties.
    [attachment=19726:IM000450.JPG]
    This is a remote filter set up. A thermostat take off plate is incorporated here ( the bit with lines going off to the right). There is a simple takeoff on the block.
    JoJo
    ACT
    Tuggeranong
    is it not good to mount the cooler side on? Does it matter?
    parrot
    Side on is fine, just not upside down as this could result in an airpocket which is difficult to bleed, not that you would know about it.
    What is important is to try and have it mounted as close to your water radiator as possible, i.e. right up against it, to stop the air just going around the oil cooler rather than through it.
    That is why having your cooler hanging off the bumper bar is a wank.
    If you have no other choice, as with transmission or diff coolers on a race car, or if an intercooler has taken up all the space, well fine. Otherwise.......
    I am sure a cooler mounted somewhere by itself will still cool the oil, but if you are going to go to all the trouble and expense, and it is easy enough to do, then why not.
    Eddie
    Gilly: Normally thermostat plates allow 10% of oil to still flow through when closed to avoid air pockets so id say just prime the engine a bit longer and it should be fine.
    Eddie.
    Ferny Grove
    legend Eddie
    i had thought there would be some oil pass through it, pays to check though!!
    i'll just let it wind over for ages before i hook fuel and spark back to it
  1. Oil cooler kit + oil pumps + fuel rail + ae71 tach dash
    By Sam-Q in forum Car Parts For Sale
    Last Post: 26th July 2012, 11:31 PM
  2. Replies: 7
    Last Post: 28th July 2011, 07:48 PM
  3. quick oil cooler question
    By yoshimitsu9 in forum Technical - Questions
    Last Post: 4th March 2008, 05:34 PM
  4. complete oil cooler and oil filter remote locator kit
    By slide86 in forum Car Parts For Sale
    Last Post: 23rd September 2007, 08:43 PM
