Results 11 to 20 of 25
Thread: 4a problem, maybe Broken/damaged valves???????
  1. #11
    Senior Member 4A-GE Power's Avatar
    Daniel
    Oh woops. i just assumed you were talking bout a ge. You wouldn't think they run the same cranks. I know the main and big end journals are the same size
  2. #12
    gunbz-r
    so slyda ur tellin me on a 4ac, that the cam runs straight on top of valves? they have arms.
    oh u said ge, i know they dont have arms, most twin cams dont.
  3. #13
    gunbz-r
    not being patronising or whatever, but how'd u test what cylinders are running? check and make sure all the shims are there, tho that'd make noise down low, but check it. and feel all the rockers for play.
    u'd have to be unlucky to snap a crank, and i would imagin it would of made a fair bit of noise when it let go. i see it as a bit odd for a crank to sheer driving normally at 60ks, could happen but i dont see it as likely, if u were revin it hard or had it really loaded up yeh but cruisin at 60?
  4. #14
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    If it is the headgasket, what is the 'Rattle' when throttle suddenly applied?????????
    I can understand losing compression, but whats the noise?
  5. #15
    gunbz-r
    cause its not your headgasket, have u checked comp yet? pull the rocker gear out, go over it make sure nothings bent or worn, then look in all the cavaties in the head for any debree, check your valve springs, make sure they are all sitting square and are all the same height. maybe theres been a hotspot or a dry one, and a valve or two have grabbed in the head, and are stuck partionally open, theres your comp lose, and would explain a rattle sort of noise uptop, if the pistons are tappin the valve, then the noise is louder at the higher speed due to the higher frequincey it would make.
    another thing, maybe the valve springs have sagged/gone soft, then at a highr rpm valves have come in contact with piston tops, which would kill comp, and cause the rockers not to sit right in the shim.(this one happened to my b6 single cam)
    the latter is more likely, but somethins let go in your head
  6. #16
    JoJo
    ACT
    Tuggeranong
    Compression test results:
    CYL
    1 - 60
    2 - 62
    3 - 158
    4 - 156
    The head is now coming off....
  7. #17
    JoJo
    ACT
    Tuggeranong
    Just got the head off...... The headgaskt was rooted between 1 and 2 cyl........
  8. #18
    gunbz-r
    ah yeah thats good, still why was it rattling?
  9. #19
    JoJo
    ACT
    Tuggeranong
    Toymods boyz reckon the noise was 'detonation'........
  10. #20
    Veteran slide86's Avatar
    Huw
    Hills
    <div class='quotetop'>QUOTE (Maxhag @ Jan 1 2008, 05:59 PM) </div>
    i am the king of the world
  1. 4A-C PROBLEM
    By 4a-cnt in forum Technical - Questions
    Last Post: 19th July 2008, 07:01 PM
  2. t50 4A bell -> t50 2T gbox seal problem
    By PULSE in forum Technical - Questions
    Last Post: 15th June 2008, 12:29 PM
  3. valves
    By slidn_ways in forum Technical - Questions
    Last Post: 7th November 2006, 12:28 PM
