Results 1 to 10 of 17
Thread: Rotating turbos
    Reeece
    Casula
    Hey guys can you rotate turbo housing ? ive got a t25g and i need to rotate it 180 degrees so the drain is on bottom, ive undone all the bolts on the turbo to see if it rotates and it still doesnt want to !! ive used hammers etc to shock it but it wont turn , now i am wondering if the t25g series can rotate at all ?
    Reeece
    Casula
    Sorry put it in the wrong section could it please be moved
    <div class='quotetop'>QUOTE (reecegze @ Jan 9 2008, 08:13 PM) </div>
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    if you have undone all the correct nuts, and the surclip, it should turn. You want it so the outlet/intercooler pipe faces down. I then, positioned the actuator where it will work and the bolted (drilled 2 holes) the actuator mount to the (approx 1cm ) edge of the compressor housing (edge faces rear of car). Be careful here, you need the right sized bolts (length and width) or you might fuck something. I then cut the actuator ROD, and welded it together so it was the right length...
    I did this 3 years ago (and had NO problems), so iam trying to remember what i did....I am not the best at explaining stuff, but i will get those photos for you in the next few days (very busy at work).
    J Riftin
    Whitchy
    Central Coast
    Dude, be careful smashing it with hammers and shit! They can rotate, my mate did it to his. But he sold it to some idiot who beat the shit out of it trying to rotate it again to fit his car, it didn't budge for him either so he took it to a shop, and they did it properly, think they had to heat it up first, but it was too late he had already f**ked the turbo from beating it sensless trying to rotate it!
    JoJo
    ACT
    Tuggeranong
    lol lol ....... what a retard!
    Sameul
    Bulleen
    Try Nissan Silvia dot com
    Search for "Clocking"
    Reeece
    Casula
    Yer i have thought about heating it but its got seals and it could cause damage, max thats the thing it should turn but it doesnt so it must be rusted / corroded. Ill try to soak it in wd-40 more
    Benn
    gold coast
    heating it might damage it, what? as opposed to the 400-600deg c it'll will see while it's on the car.
    just heat the houseing, you won't damage it.
    JoJo
    ACT
    Tuggeranong
    Benno is correct. the turbo is proberly the hottest part of the car! I doubt you could even find a way to heat it as much as it would in action.....
    sorry about the delay with the photos, i dont even have time to scratch my nuts, let alone take photos. I will take em on the weekend....
    BUT, I dont think heating it will help tho............
    Can YOU take photos of what your doing? i might be able to help you more that way, for now anyway......
    J Riftin
    JoJo
    ACT
    Tuggeranong
    how are you trying to rotate it?
  1. KKR Turbos?
    By Beau in forum Technical - Questions
    Last Post: 25th August 2024, 07:50 PM
  2. 2 x T28bb turbos
    By wideslider in forum Car Parts For Sale
    Last Post: 3rd January 2010, 11:30 PM
  3. n1 turbos (pair)
    By .wolfwood in forum Car Parts For Sale
    Last Post: 12th February 2007, 07:15 PM
  4. KKR turbos anyone use??
    By stylz in forum Technical - Questions
    Last Post: 25th May 2006, 08:45 PM
