Results 1 to 10 of 10
Thread: 1983 Toyota Sprinter 11 Months Rego
    Apr 2006
    Just putting my ADM 1983 Toyota Sprinter FOR SALE - its metalic dark blue, the paint is in very good condition, one small spot
    of rust in the hatch
    it has 11 months left of rego
    the car runs very well, everything has been properly set up, not corners cut
    kilometers: 128 thou on the engine, runs great
    Mods:
    JDM trueno bigport 16v 4age - JDM loom and JDM ecu
    4-1 extractors, 2 1/4 exhaust with resinator and 1 muffler(mandrel bent)
    JDM Disk Brake Rear End With 2Way Kaaz LSD
    Just had diff center serviced with BRAND NEW Toyota 4.7 Crown Wheel And Pinion Put In
    Rebuilt Front & Rear Brake Calipers
    JDM Front Brakes
    VL turbo fuel pump external pump,fuel lines etc made up
    JDM t50
    TRD Leads
    Alloy Air Box With Flat Pannel Filter
    Replaced alot of the hoses, radiator hoses etc.
    Nulothane trailing arm bushes
    JDM Jap accelerator pedalSparco Bucket Seat
    Nardi wheel
    Raza Shift Knob
    D1 Quick Release
    Top Stage Front Lip
    Jap brake booster
    Jap clutch master cylinder
    Jap dash cluster
    C's short shifter 55% less throw
    RDA Slotted/Vented Rotors
    When Engine Was Put In The:
    Cam belt,Dizzy cap,Throttle cable, Heater Hoses Were Changed
    Custom lower control arms 30mm longer each side
    Custom roll centers 50mm
    Koni adjustable front shocks short stroke ( FRONT COIL OVERS)
    Koni adjustable rear shocks short stroke
    Koni coil over kit (Top Hat Etc)
    Custom Spring Heights Front And Rear
    Cusco camber tops
    Nolothane caster rod bushes Replaced
    Lower ball joints Replaced
    Whiteline traction brackets
    Whiteline Front Strut Brace
    New Radiator When Engine Was Put In
    Front And Rear Wheel Bearings replaced
    Tail Shaft Center Bearing Replaced - Two Piece Tail Shaft
    Reconditioned Alternator
    MA61 wheels 14x7 -8j offset Professionally Powder Coated Gunmetal
    185/60/14 Federals. Heaps Of Tread Left.
    24mm whiteline adjustable front sway bar
    Caster rod bracket spaced down to remove anti-dive
    White line pan hard rod adjustable
    4.77 Crown Wheel and Pinion Gears BRAND NEW
    Sparco Bonnet Pins/Clips
    Top stage Front Lip
    5 Point Roll Cage SAFETY 21
    Stripped Rear Seat & Carpet, Painted Grey Hammer Tone. Comes With Seats Ect
    Its Running
    Caster - +5 +5
    Camber -3*35 -3*
    Toe - 2mm Out
    Very Clean Inside And Out, Goes Hard, Handles Great,
    NEVER DRIVEN ON THE TRACK
    ALWAYS LOOKED AFTER
    ALWAYS USED GOOD OILS ECT
    Price 9500
    Will Get Pics Up After i Wash It.
    Pm Me Or Reply In The Thread.
    ONE SMALL PIC IN AVIATOR. PICS SOON.
    [attachment=21274:IMG_0121.jpg]
    Jul 2006
    This is a very well put together car whoever gets it is getting a very good buy.
    Apr 2006
    thanks 83ae86
    also comes with massive broadway mirror
    am neg on price. needs to sell asap
    Poh
    Bevo
    seen this car through the whole process down at the mechanics
    carried out by a professional and worth every cent
    buy buy buy
    Apr 2006
    thanks poh
    Sutherland
    Hmmmm...
    I like it alot, $7500?????
    Apr 2006
    wideslider pm'dd
    also a pic is up..
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    sounds like a top quality machine
    Apr 2006
    thanks maxhag .
    will sell for 9000 with out cage..
    Apr 2006
    SOLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLd
  1. 1983 Mazda 626 Coupe 12 months Rego 78,000ks
    By wideslider in forum Cars for Sale (Not Toyotas)
    Last Post: 17th December 2012, 05:58 PM
  2. SR20 KE70, 240KW, 11 second QTR mile, 6 months rego
    By GOODY in forum Cars for Sale (Toyota Only)
    Last Post: 26th March 2012, 09:54 AM
  3. 1981 Ke70 Toyota Corolla Wagon [8 Months Rego]
    By x744 in forum Cars for Sale (Toyota Only)
    Last Post: 20th February 2012, 07:38 PM
  4. 1983 Toyota Corolla KE70 5 Speed 12 Months Rego
    By wideslider in forum Cars for Sale (Toyota Only)
    Last Post: 23rd January 2011, 12:26 PM
