Results 1 to 10 of 10
Thread: 4age engine, 4age block, ecu, loom, gearbox
    Hey Hey,
    For sale:
    1) Rebuilt bigport head.
    2) Bigport loom.
    3) Bigport Ecu.
    5) 40 thou over sized 3 rib block.
    6) 3 rib block, Missing pistons, oil pump, crank, sandwich plate, bare block.
    7) Coil and igniter, Good nick.
    8) Map sensor, good nick.
    1) Rebuilt 4000km ago, Still on car and running, Can see running.
    2) Good nick, semi cut, Converting my ae82 to 20v so i need some of it, Still very usable.
    3) Good nick, Works well, Can see running.
    5) Glazed bores, Rattle in number 3, Suspected bearing noise, BARE BLOCK.
    6) BARE 3 RIB BLOCK
    7) Good nick
    8) Goos nick.
    1) $400 firm, Have receipt for $640
    2) $100 ono
    3) $50
    5) $20
    6) FREE.
    7) $150
    8) $30
    If you need any other 4age ae82 parts just ask.
    Brisbane only, No postage at all.
    Senior Member JDM_KING's Avatar
    jake
    West Side
    you have pm
    <div class='quotetop'>QUOTE (medwin46 @ Feb 14 2008, 11:42 AM) </div>I have four 4age ae82 bigport injectors, All seals and filters replaced 4,000km ago and flow benched $70
    Also have bigport manifold = $100 complete.
    Rebuild bigport dizzy = $50 or $25 exchange.
    Stock bigport exhaust manifold and heat shields = $25
    riojin
    does the manifold come with the throttle body and TPS? if so pm me
    <div class='quotetop'>QUOTE (riojin @ Feb 22 2008, 09:31 PM) </div>Sure does.
    Loom ECU and dizzy sold pending payment.
    Bump.
    Now wrecking ae82 twincam seca
    Hey Hey, ive found a new project so I'm selling my ae82 or stripping it out, New car is also RWD.
    Car is 12/86
    1) Rebuilt bigport head = $400
    2) Bigport loom = $100
    3) Bigport Ecu. = $50
    5) 40 thou over sized 3 rib block = $20
    6) 3 rib block, Missing pistons = $30
    7) Coil and igniter, Good nick = $150
    8) Map sensor, good nick = $30
    9) C52 good nick, = SOLD
    10) 200mm 4ag flywheel and clutch $75
    11) thermostat housing, New thermo switch = SOLD
    12) 4AGE ae82 injectors, cleaned and flow benched = SOLD
    13) FWD inlet manifold with tvis plate = $100
    14) Rebuilt bigport dizzy = SOLD
    15) FWD exhaust manifold with heat shields = SOLD
    16) Radiator, ok condition = $20
    17) All timing covers, complete = $40
    18) AE82 twincam adjustable white line rear sway bar incl bushes = SOLD
    19) complete twincam struts incl brakes = $100
    20) BRAND NEW KYB sealed struts = $400
    21) 15x6 alloys = $300 with tires or $150 without.
    22) Head lights, indicators, taillights, parkers = $20 a piece
    23) Doors = $40 each
    24) bonnet = $30
    25) Rear hatch = $40
    26) Parcel shelf with 6x9 holes, very good nick = $50 with fusion 6x9's
    27) JVC CD/mp3/wma player, very good nick = SOLD
    28) Front seats, no tears or stains = $60
    29) Rear seats, no tears or stains = $30
    30) fuel tank complete with pump etc = $50
    31) massive door pods with map pocket = $40
    32) tacho dash showing 300,000 = $40
    Any other bits you need or want just ask, Complete car so everything is available.
    Located on the south side of Brisbane. May post some items at buyers expense.
    Des
    Veteran Nikkojoe's Avatar
    Tom
    The secondaries exhaust flange (one which bolts up to manifold).
    Possible to get that? If so let me know a price with postage to perth.
    Also, would you post loom aswell (may be interested).
    <div class='quotetop'>QUOTE (Nikkojoe @ Mar 4 2008, 02:29 PM) </div>don't want to cut the exhaust up as of yet.
    Loom is about $120 posted.
  1. 4age Ae86 Zenki Ecu + Engine Loom
    Last Post: 8th August 2012, 02:41 AM
  2. Replies: 6
    Last Post: 24th January 2012, 02:52 PM
  3. Fs: 4Age Loom+Ecu, T18 Pedalbox, Ae71 Gearbox Xmember
    By gmh6.0l in forum Car Parts For Sale
    Last Post: 13th December 2011, 05:06 PM
  4. TAS - 4age, loom, ecu, gearbox - 1400
    By dungbox in forum Car Parts For Sale
    Last Post: 22nd July 2011, 03:23 PM
  5. WANTED: 4age, Loom, Ecu, Gearbox...
    By d_spec in forum Cars or Parts Wanted
    Last Post: 25th February 2008, 09:59 PM
