Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 11 to 20 of 60
Thread: 4ac accessories
    Veteran Nikkojoe's Avatar
    Tom
    Yep, 2 alternators and 2 starters.
    All work fine. One alternator is recent reco'ed and $40, the other is old looking at $20. Both starters are $20.
    Postage extra, will get pics if required
    Ade
    SYD, Inner west
    how much for spark plugs and leads?
    AE86....robbing me! check the build.
    http://www.ae86drivingclub.com.au/fo...read.php?t=445
    Tom
    Leads and plugs $30ono. Leads are bosch super sport, still have the tags and plugs lucky if 100km on them (just changed before BHG - still have packet and old plugs).
    Also clutch and pressure plate, standard aftermarket item, looks like plenty of life left. Will suit 200mm flywheel (therefore 4age and 4ac), $50 ono
    PM's replied
    Tom
    Bump
    Tom
    Also have 2 4ac voltage regulators (box which bolt to strut tower).
    1 is pretty much brand new, the other is unknown age. Both work.
    $40 for new reg (cost $75)
    $10 for old reg
    PM's replied
    Tom
    All prices ono
    Tom
    Final day tomorrow
    Tom
    Final call I spose
    Tom
    Main bits left over from long motor are still for sale.
    Few things to list:
    -Near new spark plugs and leads $20 set
    -Old 4ac leads $5 set (super thick 9.5mm cables, bright yellow and red - they work afaik)
    -4ac Dizzy (ae82) $10
    -Bosch Coil (to suit ae82 dizzy) $10
    -Near new voltage regulator $30 (1 old but working, $10)
    -Clutch and pressure plate, suit 4ac and 4age $30
    -4ac Carby (worked) $5
    -2x 4ac flywheels $5 each
    -2x 4ac Starters $10 each
    -4ac Water pump backing plate with thermostat, $10
    -Top 4ac water outlet $5
    -4ac AC compressor with belt, bracket and tensioner $20
    -2x 4ac alternators with bracket, one reco'ed, other old. Both work, $20 reco'ed, $5 old.
    -4A rwd sandwich plate (between block and box) $5
    -4A metal engine brackets/mounts and gearbox brackets $30
    May have missed something. PM me if you are after a part.
    Senior Member sdm86's Avatar
    May 2010
    Scott
    Tas
    Devonport
    pm sent
  1. KYB AGX Shock Absorbers and accessories
    By Anthony in forum Kaizen Garage
    Last Post: 15th November 2012, 08:57 AM
  2. New illest accessories + V2LAB gear!
    By motorculture in forum Zen Garage / illest
    Last Post: 19th September 2012, 08:48 PM
  3. T3 CAMBER TOPS, TURBO ACCESSORIES
    By LOWAE86 in forum Car Parts For Sale
    Last Post: 26th April 2007, 10:39 PM
  4. WTB: Chrome Bumpers / Accessories Ke70
    By Teddy in forum Cars or Parts Wanted
    Last Post: 10th January 2007, 10:46 PM
