Results 1 to 10 of 12
Thread: how much oil?
    Bert
    how much F***king oil should a T50 hold, ive spent the last 45mins trying to get the filler hole open and i can't, i just smashed myself in the face with my breaker bar as the nut eventually rounded itself.
    i will be now filling oil thru my shifter, and if anyone can enlighten me as to how much oil i should put in, my car can go for a drive this evening.
    thanks guys
    Veteran Nikkojoe's Avatar
    Tom
    Wet fill I was told was around 1.3-1.4L, dry fill is 1.7L (which is usually never the case unless its a fresh rebuilt box).
    Tip for future reference. Remove the filler plug before the drain plug and if it wont come out measure how much oil came out or read the owners manual.
    All ways try and remove the filler 1st.
    kravit
    bowen hills
    I've done exact same thing, accept round it off. Have you tried smashing on smaller size ?
    Might be handy to buy set of these, dealing with old cars its going to happen more then once
    pair of vice grips worked best thanks to a dodgy person...st.r....had tried to use a chisel to open the plug only prob the chisel was also one the box casting thus it didnt open but pair of vice grips worked a treat....
    Senior Member Paw-DK's Avatar
    Mar 2010
    Paw
    Denmark
    General Area
    Christensen
    i heard some people weld on another nut onto the rounded nut and use the new nut to break the mofo open
    thats if you can be bothered haha
    get a cold chissle on it! it works trust me do it at work all the time, but you need a new not non the less
    Elite rthy's Avatar
    Leo
    Tulla
    hey where do you live? I have a tool that should work well on it, its like a vice grip but for pipes. Either that or the oversized multigrips I have
    Bert
    <div class='quotetop'>QUOTE (Sam_Q @ Mar 16 2008, 08:59 PM) </div>i live in Camberwell/Hawthorn area, i ended up just chucking about 1.7 litres in it anyway, drove it aroudn the block a few times, twas running shit, due to the alternator not working propperly....I'm assuming it felt like shit at 4k+ because of the drained battery and the alternator not being wired correctly, therefore not being able to charge the coil fast enough? i hope thats the case, otherwise the engines a bit funny. haha
    Elite rthy's Avatar
    Leo
    Tulla
    did it sound like a bad misfire at higher revs? because I had that once before when my alternator died and it didnt get the 14V it needed.
  1. Oil cooler kit + oil pumps + fuel rail + ae71 tach dash
    By Sam-Q in forum Car Parts For Sale
    Last Post: 26th July 2012, 11:31 PM
  2. FS: Omori Oil Pressure & Oil Temp Gauges
    By Nebuchernezzer in forum Car Parts For Sale
    Last Post: 14th November 2007, 07:50 PM
  3. complete oil cooler and oil filter remote locator kit
    By slide86 in forum Car Parts For Sale
    Last Post: 23rd September 2007, 08:43 PM
  4. omori oil filter relocation kit with oil temp and pres guages
    By ae86 slide in forum Car Parts For Sale
    Last Post: 21st March 2007, 07:04 PM
