Located Brisbane. 0416 193 936
AE86 PARTS
Bare halfcut chassis. Small patches of rust, had a light tap to the front: $50 Pick Up only
Gearshift Surround $30
[attachment=26169:shifter_surround.jpg]
Steering column Under panel $40
[attachment=26170:under_column.jpg]
Air con switchblock surround $35
[attachment=26171:AC_surround.jpg]
Underdash crossbar - $30
[attachment=26456:Crossbrace.jpg]
Rubber boot around shifter - $20
[attachment=25454:boot_1.jpg]
[attachment=25455:boot_2.jpg]
Throttle Cable: $20
Gas Pedal: $20
[attachment=26459:Accelera...nd_cable.jpg]
JDM Zenki Cluster 96k Has a cracked clear cover (thanks mr towie), but the rest is fine and working. $75
[attachment=26172:dash_plastics_002.jpg]
AE86 speedo cable, has a nick in it, but spins fine: $15
[attachment=26457peedo_cable.jpg]
[attachment=26458amage.jpg]
AE86 Underdash metal braces, set of 3: $40
AE86 Clutch Pedal assembly: $150
AE86 Brake Pedal Assembly: $100
AE86 Bonnet hinges: $30 Pair
AE86 door hinges, both sides available: $45 a pair
Aftermarket horn: $5
AE86 Switches, lights, wipers,rear demister, rear washer: $15 all the ones I have
Grill support, needs a straighten: $ 10
Plastic Grill for vents: $10
Boot/Fuel release levers, cut cables: $15
Moulded Plastic Footrest: $20
Washer motor and valve on bracket: $50
[attachment=26464ick_a_part.jpg]
AE86 Undercarriage, swaybar, caster bars, and mounts: $80
[attachment=26463:Caster_sway_bars.jpg]
Front end Body loom with factory fusebox: $150
[attachment=26462:Front_bODY_lOOM.jpg]
Underdash Body loom with fuses relays and all plugs, $150
[attachment=26461:Undrdash_loom.jpg]
Aircon Stuff inc vents, fan box, ac condenser, lines, heater core, and switchblock: $100
[attachment=26465:AC_stuff.jpg]
AE86 Digital dash Clock and surround: $10
AE86 Strut tops $20
Din Console surround - $40
Tokico Illumina 5 way adjustable shocks - One perfect vgc, one stuffed. Great if you have an odd one you want to use $60ono
ALL the plastics I have and random remaining bits of interior, plus the cluster, $180 the lot shipped.
