That sounds ok. Each fuel pump should have its own relay. Battery power should go to both relays. EFI fuel pump wire should be the signal to turn the relays on.
I think on a standard Toyota car, the fuel pump relay is called "circuit opening relay" and is in the dash somewhere.
