theyre a good engine like all 4a's are. if youre a lover of torque theyre well worth it. the reason i went for a gze is i wanted a 4cylinder that felt like i was driving a 6cylinder.
T50's hold up fine aslong as you know how to shift properly.
i am using a 15psi nevo pulley kit which works great. its running at 14psi because i have a front mount intercooler and you lose 1-2psi with them. the difference between the 15psi and the stock 8psi pulleys is extreemly noticable.
I'm running the stock ecu which works very well even with a modified engine. apparently aftermarket ecus and gzes are a bitch to tune.
i have a 3inch exhaust system which is using a cat and muffler and its loud. at idle it sounds like a normal 4ag but when you rev it it sounds like a beasty rotary.
my belts are tensioned properly and my sc runs from idle all the way up to my limiter at 7250rpm. it doesnt push as hard torque wise when revved over 6000rpm but it produces more power above 6500rpm.
i have a 4age bigport throttle body in my posession which i was planning to put on but i may have sold the car before ill get a chance.
all in all i feel 4agze's are a fun car and are much faster than the average NA but they are still pretty slow. theyre better for the beginner drifter because if you drop revs you getting higher torque so you can continue the drift.
