Results 1 to 10 of 11
Thread: 4age keeps dying
    Joash
    Tasmania
    North west
    Just bought a car, bought it with the engine not running and I'm now trying to get it going, its a jdm rwd bigport.
    Apparntly the morning i went to pick it up he said it started first thing, ran for about 5 mins then died. Now wont start again
    Its not getting any spark
    help please
    Ive checked basics
    Veteran slide86's Avatar
    Huw
    Hills
    igniter or coil?
    is there 12v on the positive side of the coil when the ignition is on?
    Joash
    Tasmania
    North west
    yea i got 12v on that side just no negative pulse
    so prob not the coil cause its not getting the trigger to do its job.
    Dizzy ecu maybe?
    how do i test these
    Huw
    Hills
    could be the igniter.
    ive seen one of these fail on a 4age causing exactly the problem you are describing. I'm not sure how to test for pulse from the dizzy.
    id try and get another coil and igniter assembly, plug it into your car and see if it starts. are you able to borrow one?
    Jul 2010
    Kieren
    Have you checked the alternator and the battery.
    The alternator may have died and the battery may have only had enough to start it then sustain the engine for 5 mins.
    Could be many reasons or a combination of them but alt and batt is where I'd start my checklist.
    On another matter, I once bought a car that did the same as yours did.
    The engine would not start afterwards.
    After a long hard think, I wondered why the engine was so clean.
    It turned out the seller ran a last minute degreaser job causing water to gather above the sparkies.
    It was a simple matter of a blow out with a little denatured alcohol to get the car working fab.
    Just added that to remind you some problems may seem really bad but can turn out to be really basic.
    So don't get too disheartened at your new purchase.
    Hope you get it all fixed buddy without too many dramas.
    Joash
    Tasmania
    North west
    cheers man
    well as for the battery its cranking the engine fast as, hasn't showed signs of dying yet
    yea the wiring is a mess to, if i had wired it myself id know what was what etc lol
    Joash
    Tasmania
    North west
    Ok so i went back tonight for anothe rlook
    checked the main pins at the ecu
    Earth pins are earthed, batter pins have battery
    However this pin IGt i take by the information below (gathered from club4ag) is supposed to have a positive signal when the engine is firing.
    Can anyone confirm this as this pin has no power on it.
    IG t Black/Blue Igniter Assembly Ignition timing signal
    The coil has ignition on both sides which I'm sure is how its supposed to be untill the distributor sends a negative signal to the negative side, which it is not doing.
    I also have to work out why i no longer have fuel pump working, the circuit opening relay has a positive out put to the fuel pump when its cranking over but its still not operating/priming.
    Ahh can anyone help me, I'm starting to think that a dizzy change is on the cards
    Joash
    Tasmania
    North west
    Also to add the previous owner said
    wouldn't start, came back 2 weeks later started first time then died
    This happened to him twice, waited another 2 weeks etc
    Friggen cars
    Veteran Nikkojoe's Avatar
    Tom
    The standard fuel pump circuit opening relay does not prime when you turn the ignition on. It only pumps fuel when you are cranking or the engine is running.
    Joash
    Tasmania
    North west
    Yea realise that man :greenbounce:
    Not even doing it off the start key atm but when i do hit start the relay is energizing and doing its job, its just not working, so must be at the pump somewhere.
  1. [VIC3691] 1982 ke70 wagon + a dying 4ac
    By Casey-G in forum Cars for Sale (Toyota Only)
    Last Post: 28th May 2012, 12:57 PM
  2. 4ac is dying
    By khai2298 in forum Technical - Questions
    Last Post: 12th July 2010, 06:15 PM
  3. How to tell if gbox/diff is dying?
    By tc-rolla in forum Technical - Questions
    Last Post: 15th January 2010, 03:04 PM
  4. Dying waterpump?
    By ae86 slide in forum Technical - Questions
    Last Post: 21st June 2009, 12:40 PM
  5. 4age cam cover! I'm dying for it!
    By doridori in forum Cars or Parts Wanted
    Last Post: 12th May 2007, 02:11 PM
