Results 1 to 10 of 19
Thread: LIMP MODE
    Bert
    hey guys,
    sorry to start this up again, i thought i would start a fresh thread since the topics kinda changed a bit compared to a few months back..
    over the last few months, ive been trying alot of things with my car.
    i will recap info about my car, charataristics of driving etc.
    Car is a ADM sprinter with a JDM 4age with un-molested loom and matching ECU
    1. the car runs SOOOO rich, did about 90km to 3/4 of a tank
    2. the car makes a lot of torque betwwen about 1500-3000 (don't have working tacho but at about 30km/h in 2nd gear)
    3. the car revs and sounds normal with no load on the engine (in neutral)
    4. the car struggles to rev over about 3000 and makes a lot of noise and doesnt go any faster.
    5. i just went in a JDM 4age yesterday, and it actually revs and makes power higher up, which mine does not.
    is it safe to assume my car is in limp mode, as a few people have been telling it isnt.... :blink:
    i can rule out Map sensor as i have bought a new one and tested it, the TPS seems to be working fine, timing is fine, changed the plugs, it made it idle better thats is...
    i bought an AW11 dizzy cap, i had to actually drill a hole next to the orginal one which i didnt like doing , but it sits on straight and fires normally and idles even better, but that is is ONLY improvment.
    this car is not running an 02 sensor also...(but i am told it shouldn't make to much off a difference, just make crappy fuel ecconomy.
    next I'm about to get an ignitor and coil, but i also fear this will have no improvment, so i ask you experienced guys for help again.
    then i was thinking about my knock sensor, and is there any way to test if this is working correctly?
    Also i went to toyospares in melbourne, and the guy there said "well if you don't have all your factory sensors your ECU's gonna say FUCK YOU i want my facotry imputs and will go into limp home mode, so get a O2 and then it will work"
    but I'm not intirely sure that would be the case...
    so any imput here would be a great help, ive been saving money lately and if its not working in the next month or so, I'm just going to rip out the loom and either go twin carbs coz i can't be stuffed with EFI, or I'm going to go all out and get Aftermarket ECU and get it all hooked up and tuned..but hardly worth it if my engines remaining stock anyway.....
    thanks
    Veteran Nikkojoe's Avatar
    Tom
    There is no knock sensor on a rwd jdm 4age. And i agree that your car is in limp mode, exactly like mine was when the map sensor was technically not connected.
    I can't remember if you did this last time, but on the map sensor connector plug, check that all pins are not pushed back and all should be the same level. This is actually on the loom plug, not the map sensor plug. I swapped my map sensor with a mate and it made no difference(because it technically never made any connection). Check the continuity of all the pins from the map sensor to the ecu to see any breaks in connection.
    I'm fairly confident that its the map sensor/connection to, there are not really any other factors that will affect the fuel map (your spark timing and that stuff is fine as its running on all four). If all else fails, faulty ecu?
    Jonathan
    Since you have the factory computer and loom an everything, it maybe a good idea to also get the diagnostic engine light to also work. That way you could check for codes and be able to look up what the problem is. Your sort of in the dark without it.
    Bert
    well Jonny Rochester its funny you should say that, i just remembered i didnt tell you guys id done diag, and it said "vacuum" intake vacuum somthing...so what Nikkojoe sounds most likely, i will test the wires on the weekend, ive got work tomorrow till friday i'll let you know how it goes.
    is there a rev limit on limp mode? or is the engine just reluctant to rev, and makes no power so you wouldn't ever rev it...
    thanks guys, i was fearing i wouldn't get any feedback on this.
    Tom
    yeah, with my tacho working it rev'ed to 4000rpm (loads of torque then died in the arse at WOT above 4000). What was strange was that it would rev more if you let your foot off the accelerator slightly when above 4000rpm.
    Oh and i melted my brand new cat heaps and used 1/2 a tank in 30km
    parrot
    I would be putting the right dizzy cap on for a start.
    Out of interest, what injectors does it have?
    Bert
    well ive been trying to source the right dizzy cap for some time, someone said the Aw11 cap goes on, i ordered one, and it went on, but the bolt hole didnt line up, but, since they must use the same casting for the one i need (which i just cannot seem to find anywhere) i just drilled a holl where there was a circular mark already...and then it went on perfectly, and the car runs perfectly.
    but yes, i noticed the car really does run like shit unless you back off on the throttle, its so weird.
    injectors would be stock, i replaced the seals and sht in them when i got it (the engine), i have a VL Turbo fuel pump, but i fail to see how a bit more pressure and volume is going to make my car do what its doing.
    parrot
    Presumably you have a stock fuel pressure regulator so extra fuel will go back to the tank via the return you presumably have. A rising rate FPR wouldn't cause it either. Are you sure the injectors are stock? Colour / part number?
    Not having a go but I would really make sure the cap is the right one.
    Jonathan
    Higher fuel pressure will make it run rich. You want standard fuel pressure with a standard motor and injectors and ECU. From memory this should be about 35-40psi. The pressure should be limited by the stock pressure regulator on the fuel rail. You could check fuel pressure at the rail with a gauge if you like, if you have a gauge.
    Have you tied getting the right dizzy cap from Toyota? It probably costs too much, but I'm sure you could get one.
    Maybe you could clear the codes, (disconnect battery), and start again. Drive it and see if it still has codes. If you get a code for the MAP sensor for example, then either the sensor or the wires are at fault, and nothing else.
    I hope this helps.
    parrot
    Of note, you can get RWD 4AGE dizzy caps on UK ebay for like GBP 3.00 plus post. Look in stores.
    I run a malpassi rising rate FPR on mine with standard grey injectors without drama
  1. 4age diagnostic mode
    By extra_anchovy in forum Technical - Questions
    Last Post: 24th May 2011, 10:38 PM
  2. raw mode fail
    By RRX-007 in forum Photography & Digital Design
    Last Post: 10th February 2010, 10:53 AM
  3. wtb TRueno late mode grill
    By rthy in forum Cars or Parts Wanted
    Last Post: 4th January 2010, 08:18 AM
  4. "LIMP MODE"
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 27th March 2008, 11:57 PM
