Results 1 to 7 of 7
Thread: ca overheating help me.
    ok so ive completed my v mount setup and are equipt with a 70mm 3core alloy rad , and a kkr 110m thick inter coooler.
    but i can't keep my water temp below 100 degree.
    my old setup had the stock ca rad and a big ugly front mount and it ran about the same temp.
    any ideas?
    cheers boys.
    got big thermo fans?
    do a bonnet lift, helps hot air escape you engine bay.
    check that your thermo stat is working or replace it with one that opens at a lower temp. allowing cooler water to travel around the motor.
    if its an import motor from japan, they are spec'd differently for their cooler conditions.
    Senior Member JoshKE's Avatar
    Josh
    Launceston
    Defintaely worth checking out the thermostat...
    Even try running it without one at all to see if that's the problem if you have to
    Veteran slide86's Avatar
    Huw
    Hills
    do you have a hole in the bonnet to allow the air going through the radiator to exit the engine bay?
    a thermostat only allows the engine to reach operating temperature more quickly
    i'd opt for a cooler thermofan sensor
    Veteran Nikkojoe's Avatar
    Tom
    <div class='quotetop'>QUOTE (Bobomacho @ May 22 2008, 06:26 PM) </div>Yes but if it only partially opens water flow can be restricted and hence overheating can occur.
    ahh yes i stand corrected nikkojoe that is true,
    slipps as you having any loses through the system ?
  1. 4age overheating
    By Sprinter Freak in forum Technical - Questions
    Last Post: 1st October 2012, 09:58 PM
  2. Brakes overheating
    By flamingheads in forum Technical - Questions
    Last Post: 10th December 2009, 08:23 PM
  3. Engine Overheating
    By fozz in forum Technical - Questions
    Last Post: 17th September 2007, 02:03 PM
  4. WHY IS MY 4AG OVERHEATING
    By orangechargd86 in forum Technical - Questions
    Last Post: 19th December 2006, 02:02 PM
  5. Overheating 20v
    By _matt in forum Technical - Questions
    Last Post: 11th November 2006, 10:08 AM
