Results 1 to 4 of 4
Thread: stock ae92 4agze flywheel in t50
    Reeece
    Casula
    Hey guys i am just after the stock size of the earlier ae92 afm 4agze flywheel as its in my t50 gearbox and not konwing the previous history would it of been swapped to an n/a one to fit inside the t50 box ??? as i am having troubles trying to find the size of the t50 box
    i am going to be using a 4a nite parts bellhousing so i am wanting to see if ive got a gze or ge flywheel
    Veteran Nikkojoe's Avatar
    Tom
    It mostlikely will be a ge flywheel (either 212 or 200mm). Even though you CAN* fit a 224 into a t50, its a big fuck around and i doubt in your case it would have been done. Plus you would of had to get a custom clutch plate as the splines are different.
    *(ive recent put one in and it aint a pretty job).
    Dusty
    Lynbrook
    I have a 200mm with an exedy clutch, and i'm not a fan at all it doesn't handle the torque of the GZE on occasions
    Reeece
    Casula
    i am going to be using the nite parts bellhousing with my 4agte ... I am just trying to see if i need a new flywheel if the one in my t50 is 200mm atm
  1. wtb- smallport flywheel (ae92) -adelaide
    By z250junker in forum Cars or Parts Wanted
    Last Post: 8th November 2011, 02:30 PM
  2. Replies: 0
    Last Post: 8th December 2010, 06:21 PM
  3. AE92 flywheel into T50 gearbox?
    By PeterH in forum Technical - Questions
    Last Post: 22nd February 2010, 10:25 AM
  4. Replies: 24
    Last Post: 17th June 2009, 10:24 PM
  5. gze flywheel and clutch setup onto a 4agze (t50)
    By tom__86 in forum Technical - Questions
    Last Post: 25th September 2005, 03:04 AM
