Results 1 to 5 of 5
Thread: 4agze ignition/ecu problem
    Thurston
    Vic
    North East
    I'm posting on behalf of my internet challenged friend. Some of you may know him, Alistair Neely. He drives a red turbo ae86 at vicdrift winton days.
    The engine is an ae92 4agze with afm and coils, all the standard equip running on standard ecu. The supercharger has been replaced with a turbo and was running fine for quite some time unchanged before these problems.
    At the last drift day his car was stalling and wouldn't start hot. Left to cool for 2 mins and it would start again. It hasnt started since, it has no spark at all. He has checked all pathways and earths which all seem fine. There don't appear to be any leaking capacitors in the ecu.
    He's pretty keen to get to the next drift day in 3 weeks and we're running out of ideas.
    Please help if you can. Thanks.
    Veteran biggo's Avatar
    Nick
    Noosa
    melted coils?
    70XIN did that to his but the funny thing is the still worked!
    Thurston
    Vic
    North East
    How would both coils get rooted at the same time? How can we check them? He may already have done, i'm hopeless with electrical problems. We were more worried about the ignitor or ecu.
    Nick
    Noosa
    i have no idea, but if you want a place to start, go from the plugs backwards
    its all a process of elimination
    Veteran Nikkojoe's Avatar
    Tom
    Check coil and igniter get power to them (via black orange wire). Should get atleast 12V on ignition. Check cas operation (try swapping with a small port dizzy).
    Thats all i can think of.
  1. Need urgent help. Ignition problem.
    By dansomerville in forum Technical - Questions
    Last Post: 27th August 2011, 04:26 PM
  2. Carb'd 4AGE on Hyperpak ignition no spark problem
    By 4AGE FORD in forum Technical - Questions
    Last Post: 20th January 2011, 06:06 AM
  3. ignition problem
    Last Post: 4th August 2009, 11:41 PM
  4. AE71 ignition problem
    By AE71_Rolla in forum Technical - Questions
    Last Post: 21st January 2008, 07:40 AM
  5. AE71 ignition problem
    Last Post: 15th January 2008, 05:50 PM
