Results 1 to 6 of 6
Thread: where is the check connector?
    Sep 2006
    Thumbs up
    i need to find the check connector to short 2 pins (E1&T) to do a base timing.
    but i couldn't find it anywhere?
    is there a one in my engine loom?
    could it be near the ECU under the dash board?
    [attachment=26561:__29031_...255__042.jpg]
    and what type 4age is my engine? i have been told is it a big-port from an AE82, but not 100% sure.
    83kw? black&red top? 7 ribs? notice the dizzy cap is different to the black&blue top.
    thanks for help
    Veteran driftke70's Avatar
    Ryan
    Buderim
    little box with a curved little, says diagnosis on it, should be around your super responsive sticker inside or out.
    wheelfriends.wordpress.com
    Veteran Nikkojoe's Avatar
    Tom
    <div class='quotetop'>QUOTE (driftke70 @ Jun 2 2008, 10:25 PM) </div>Kinda correct although the ae82 bigport never had that box (afaik it was on a kouki ae86 loom).
    Your engine is a ae82 bigport bluetop (with your cam covers painted obviously). Your dizzy cap is correct for an ae82 bigport bluetop (only jdm rwd bluetop's have the different dizzy/cap).
    Now to answer your question, it is in the cluster of 3 yellow plugs below your SR sticker. The one you are looking for has a blue/white wire(T) and brown wire(E1). Bridge them together, your idle will drop so you can set the base timing
    Sep 2006
    thanks nikkojoe
    no wonder i couldn't find it
    so 10 degrees BTDC still stands for base timing on this engine?
    and when birdge is off, it should be 16 or more BTDC, right?
    Tom
    I can't remember if its 0 or 10deg when bridged but it usually increases by 10 when not bridged
    Sep 2006
    what is the need for bridging E1&T? sending the signal to ECU for base timing?
    can i just adjust it to 16 degrees BTDC with a timing light, without bridging E1&T?
  1. WTD - Ae101 TPS connector
    By Si.G in forum Cars or Parts Wanted
    Last Post: 6th July 2010, 11:06 PM
  2. 4age check connector, high idle
    By khoala in forum Technical - Questions
    Last Post: 9th April 2010, 12:27 PM
  3. 100kw ecu 12pin connector
    By Snowman in forum Cars or Parts Wanted
    Last Post: 8th October 2007, 09:56 PM
  4. tierod end connector things.
    By HiLtOn in forum Cars or Parts Wanted
    Last Post: 10th August 2007, 12:00 AM
  5. Small port ECU connector
    By RZA12 in forum Cars or Parts Wanted
    Last Post: 10th May 2007, 01:05 PM
