Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Compression Test
    Nov 2006
    So i've just recently compression tested my 4a With good results all over the board.
    My Question is on a Stock 4a 16v what Pressure reading would you expect in each cylinder?
    In Both Runs i had results of 210 Psi in all 4 cylinders.
    I don't exactly know what internals this motor has, weather its just head gasket or if its got Pistons 2.
    its running a 0.8mm H/Gasket.. Head may have been decks as-well but i'm not sure of that either.
    Veteran Robo86's Avatar
    Rob
    thats pretty high, thinner headgasket and maybe higher comp pistons.
    good comp for a stock 4a is like 170-180
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    Nov 2006
    I'm to much of a need to.... need to know that is.. the results are to high for just a head gasket i would have thought
    anyone else shed some light?
    Veteran Nikkojoe's Avatar
    Tom
    My bigport was 180psi across all cylinders when the bare engine was tested in front of me on a pallet hahaha.
    But yeah, 170-180 is good
    Andrew
    I tested a small port gze that was 195psi across all (dry).
    Nov 2006
    mayb 210 is about right with a 0.8 mm H/ Gasket... I'm not sure weather its small port or big port though, Any way to tell with the motor together?
    Andrew
    Well the intake plenum might tell you the answer, although it is possible to adapt a bigport intake to a smallport head. The bigport intake is smooth on top and usually has a small rectangular ridge cast into it for the TVIS badge. The smallport has ribs running along it lengthways.
    Someone may be able to add to this?
    My 4age after rebuilt head was 200psi on all 4
    Nov 2006
    <div class='quotetop'>QUOTE (af300e @ Jun 5 2008, 05:10 PM) </div>
    hehe getting their.. but its got Quads...
    Andrew
    hmm, not sure then. Someone will know how to tell without having to have the two side by side.
  1. AE101 4agze Compression test results
    By trikzlane in forum Technical - Questions
    Last Post: 13th May 2011, 11:58 AM
  2. Blacktop Compression Test Results
    By Matt in forum Technical - Questions
    Last Post: 4th August 2010, 02:44 PM
  3. Bench Compression Test
    By Gilly in forum Technical - Articles
    Last Post: 9th May 2008, 04:11 PM
  4. no compression
    By kaneO in forum Technical - Questions
    Last Post: 27th November 2007, 10:34 AM
  5. compression test
    By albertos in forum Technical - Questions
    Last Post: 17th June 2007, 11:19 PM
