First off, wrong forum
Next, by zero vac hoses do you mean that all the fittings have been blocked off where the lines should be?.
The plate people say goes between the base of the throttle body and the cold start valve (which has the water lines that go to it). You can make a metal plate OR get some really thick gasket paper and just block it off with that.
