Would be interested in the top water outlet to rad and thermostat water outlet to rad if you decide to seperate. Those water pipes have the bits for cold start right?
more stuff found and needs to go after more tidying up today
1. a COMPLETE rwd water setup for 4age. this includes waterpump x2, rwd housing and thermostat, rwd lines, rwd housing on back of head, rwd upper outlet at front. (WILL NOT SEPERATE AT THIS STAGE)
2. s13 front hubs, calipers and rotors from a ca18det silvia
3. s13 5 speed box from a ca18de silvia
4. 25mm neg RCA for ae86
5. HEAPS OF CA18 SPARES. 2 boxes full, just ask for what you need
6. slanty headlights in excellent condition from te71 (same as ae71)
PRICES
1. 220
2. 175
3. 200
4. 100
5. POA depends what you need.
6. 120 for both
I'm in adelaide. the heavy stuff (gearbox, hubs) i wont post, but the other stuff is no worries
PM or 0406004171 (not before 11am)
thankyou
[attachment=27096SC02163.JPG]
Hey, If that water kit is to convert a 20v to RWD I'll take it,
I am assuming the RWD water set up is factory jdm for a 16 valve.
If I'm right, PM me your bank details please slide86! Oh, and cost for freight to 2325.
Cheers!
Driver of the yellow ae86
http://www.ae86drivingclub.com.au/fo...hlight=custard
water kit sold pending payment
Water kit paid for - can you please respond to my PM slide86? Cheers
damn it I check every day and i still miss out on the stuff i need!!![]()
"Find" another rwd water setup for and i'll buy it !!! Though one question is could i use the front wheel drive 4age water pump with an ae71 back half ??
Cerby
ill see what i can find for you![]()
SCHWEET!!!!! If i can use the fwd pump then i won't need another pump cos i ahve heaps of them![]()
Is it a pair of Hubs for $175?
