Results 1 to 5 of 5
Thread: 4AGE questions
    Senior Member PHAT86's Avatar
    Allan
    Brahma Lodge
    Hey, I just had my bigport FWD 4AGE rebuilt and in the process of putting main things back on. It will be getting installed
    into my AE86, i have 2 questions that i need to know, all the rest of the stuff i have sorted.
    1. Can i use my RWD 4AC starter motor if i use the 4AC flywheel, clutch and pressure plate?
    2. Do i have to install a spigot bearing on my 4AGE or can i use the one from the 4AC?
    Any advice will be really helpfull.
    Cheers. Allan
    Troy
    Baulkham hills
    I think you can use the 4AC starter - but your 4AC flywheel wont fit the 4AGE - 4AC flywheel uses 6 bolts, 4AGE uses 8.
    Veteran Nikkojoe's Avatar
    Tom
    1. If your 4age has a 200mm flywheel then you can use the same 4ac clutch and pressure plate. The 4ac starter will work on any 4a flywheel as they all have the same ring gear (even 4agze 224mm have the same ring gear).
    2. Buy a new spigot bearing, bearing part no. 6001 (or just ask one for a 4ac sprinter) from any bearing shop and should cost less than $10. Not worth the effort of pulling one out of the 4ac
    Elite rthy's Avatar
    Leo
    Tulla
    Spigot info
    Allan
    Brahma Lodge
    Thanks heaps guys thats really usefull :2thumbs:
  1. 4age questions
    By RhysE in forum Offtopic Discussions
    Last Post: 1st August 2012, 08:27 PM
  2. 4AGE questions
    By Sprinter Freak in forum Technical - Questions
    Last Post: 12th May 2011, 02:27 PM
  3. 4age questions
    By keimeier in forum Technical - Questions
    Last Post: 26th March 2010, 11:53 PM
  4. 4AC-4AGE Questions
    By mattty in forum Technical - Questions
    Last Post: 10th January 2009, 05:00 PM
  5. 4AGE just some quick questions
    By h i t o r i k o in forum Technical - Questions
    Last Post: 11th September 2008, 04:02 PM
