Results 1 to 9 of 9
Thread: 4age wiring Q's
    hey guys, just wondering, is a 4age bluetop motor wiring harness is compatable with a redtop (non tivis) engine?
    just wanna swap over the motor and not have to change wirring
    Veteran slide86's Avatar
    Huw
    Hills
    no i think they are different
    by the look of the wiring diagram there are some differences and the injector plugs might be different
    the sensor plugs are different aswell arent they?
    Veteran Nikkojoe's Avatar
    Tom
    injector, tps, map sensor, dizzy, igniter are just some of the plugs that are different.
    As long as you swap the sensors for the loom and ecu over, it might work ok...
    so in short it wouldn't be worth it ay
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    <div class='quotetop'>QUOTE (Johnny_08 @ Jul 18 2008, 01:17 AM) </div>My engine came like that, its a small port and was running an old blue top tvis loom and computer. It'll work you just need to swap a fair few things over. I switched mine to the proper loom because I honestly thought it would be a lot better to run it on the correct computer.
    actually it would run if i kept the same head and just changed the block wouldn't it? cause all the sensors are pretty much for the head?
    Tom
    Yep
    cool, cheers for that guys
  1. Trev's Guide To Repairing 4age Dizzy Wiring
    By Trev084 in forum Technical - Articles
    Last Post: 25th August 2008, 09:04 PM
  2. Replies: 4
    Last Post: 29th March 2008, 10:30 PM
  3. 4AGE Wiring Help
    By MrMatt in forum Technical - Questions
    Last Post: 6th November 2007, 10:18 PM
  4. 4age wiring
    By loc33e in forum Technical - Questions
    Last Post: 4th August 2006, 09:37 PM
  5. 4age wiring
    By drft86 in forum General Topics (No Technical Questions)
    Last Post: 1st May 2005, 10:46 PM
