Results 1 to 10 of 11
Thread: high oil pressure
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Hey guys just got my 4age going in my Sprinter and the oil pressure is way too high (sits on the high mark on the factory gauge while driving)
    Doesn't seem to leak oil anywhere but does smoke a bit probably due to high pressure
    The engine is a ae82 4age whith the oil cooler blocked off for now, will that cause the high pressure? Should I connect it back up and see?
    Only reason I didn't was I didn't have any hose or money to get any at the time
    Thanks for your help
    Senior Member orange32's Avatar
    Zac
    Redlands
    is the oil cooler line connected back to the engine or is it plugged up?
    If you can, connect the cooler back up and see if it goes back to normal.
    Oldschool Member
    Sep 2007
    Justin
    Western Sydney
    bypassing the cooler won't make any difference,it's a low pressure bleed off system anyway,all it'll do is just return to the sump faster.
    measure what the oil pump is actually putting out with an accurate gauge. the std dash gauge is a guide more than a measuring instrument.
    around 30psi at idle and 80 or so at higher rpm is a normal range. if it goes above 100psi,you have a siezed pressure relief valve in the pump that you'll want to free up before you pop seals or damage bearings..
    Justin...
    monkae86
    change your oil/filter
    Nutter86
    Exclamation
    Hey stop! don't run it anymore as the blocking of the hoses is the oil relief as well as oil being cooled on the return to the sump. You can connect the pipes with a short piece of hose to u it back in.
    Veteran Nikkojoe's Avatar
    Tom
    If not running a cooler for now, remove the sandwich plate and put the 4ac oil filter stud/screw in its place.
    Block the sump return....
    Jordan
    Sunshine Coast
    fitted the factory oil cooler today but it didn't make one scrap of difference
    guess I have to pull the sump off and have a look at the release valve
    cheers for the replys people
    mattyn
    i have noticed this same thing in my 4age but assumed the gauge was out.
    <div class='quotetop'>QUOTE </div>however i do have a dented sump.
    would this dent foul anything, such as this pressure relief or is that part of the pump ??
    cheers
    Veteran slydar's Avatar
    Dimitri
    the gauge is calibrated for a 4ac, so it will read high. also, do you have the 4ac sender in there, or the ae82 4age one? should have the 4ac one in there.
    78's
    Jordan
    Sunshine Coast
    4ac sender in the block so if i fit a jdm cluster it should read normal range then?
  1. Replies: 4
    Last Post: 16th May 2011, 01:13 AM
  2. external high pressure fuel pump,
    By 4ag te72 in forum Cars or Parts Wanted
    Last Post: 28th February 2011, 01:18 PM
  3. FS: Omori Oil Pressure & Oil Temp Gauges
    By Nebuchernezzer in forum Car Parts For Sale
    Last Post: 14th November 2007, 07:50 PM
  4. VL high pressure fuel pump
    By deleta in forum Cars or Parts Wanted
    Last Post: 11th April 2007, 04:10 PM
